XGRASS DISPLAY LIB ERROR
srpage wrote:
XGRASS DISPLAY ERROR: Not enough colors available. Make more available
before starting again.
I have XFree86 configured for 16bit color, so I do not beleve this is the
problem.
It probably is the problem: the standard grass monitor can't run at colour
depths of more than 8bpp. Try starting your x server in 8-bit mode and see if
the problem goes away. If it does, then there is a (still 256 colour) monitor
which runs on higher bpp servers somewhere, so you could compile this and run
your xserver at 16bpp.
David Wheatley
Department of Archaeology,
University of Southampton,
UK, SO17 1BJ
