Hello all.
After finally getting Solaris 2.3 to run, I got the error:
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 78 (X_CreateColormap)
Serial number of failed request: 265
Current serial number in output stream: 266
aError - Can't set up pipe to graphics device.
Problem selecting x0. Will try once more
when I tried d.mon start=x0 from the Control Display Monitor.
Anybody ever seen this one, and have an answer?
If this in the FAQ, sorry, I haven't found it yet, but would love
to recieve a copy of it!
thanks
Brian
_____________________________________________________________________________
Brian Aker | brian@jumpriver.antioch.edu
Yellow Springs, Ohio. | brian@antioch.edu
_______________________________/_\___________________________________________
You can't grep a dead tree. / \
