XGRASS illegal help data error
Dear XGRASS Users,
I installed xgrass4.1 on HP9000/715, and most things work fine, except that
the xclip interfaced commands give an error message like
"/ill2/grass41/etc/xclip/d.vect", line 75:
<Illegal help data [12.map.display/12.05.d.dis]> at or near """
The reported line number is arbitrary, the help files exist and are found
and displayed by the xghelp system from the main menu.
I can work around the problem if I comment out the helpwidgetref statements.
Any simple solution?
Josef Fuerst
Dipl.Ing. Dr. Josef Fuerst
Universitaet fuer Bodenkultur
Institut fuer Wasserwirtschaft, Hydrologie und konstruktiven Wasserbau
Nussdorfer Laende 11
A-1190 Wien
AUSTRIA
Tel: +43 1 3692924 360
Fax: +43 1 3692924 350
E-mail: fuerst@donau.boku.ac.at
I had the same problem on the HP 9000/715, after looking at the source-code
i saw a little problem in the file xgrass/menu/xc.create.c at line 3400
in the funktion _XcParseHelpData, they are returning no value (or think that
it is default 1), so i replaced the 'return'-statement with 'return 1' and
it works.
Good Luck,
Ron Doornink, ITC Enschede
E-mail: doornink@hp30.itc.nl
