xgrass make on a DEC 5000
GrassHoppers:
     While trying to gmake4.1beta xgrass on my DEC 5000/200, I keep getting
messages like this:
ccom: Error: /usr/include/X11/Xm/Xm.h, line 2111: syntax error
      typedef XtPointer (*XmResourceBaseProc)();
    Does anybody know what I'm doing wrong? Has anyone made xgrass on a
DEC 5000?
William W. Hargrove (615) 574-1902
hnw@mtqgrass.esd.ornl.gov (615) 576-8646 (fax)
The culprit here is how you are identifying the various X library and
include paths. The standard Xt (ie toolkit) stuff is modified a bit
to work with motif, so if you use Xm you have to use the revised Xt.
Unfortunately, the utils/setup procedure will often find the standard
Xt automatically, and then ask you for the location of Xm. The
implication of this is that you need to edit the head/dec file
manually, and set the appropriate paths.
If you have the DEC-issue motif libraries and includes, this is
generally in a directory called /usr/lib/DXM. You can then specify
the appropriate paths as follows (extracted from head/dec):
XCFLAGS = -D_NO_PROTO
XLDFLAGS =
XEXTRALIBS =
XINCPATH = -I/usr/lib/DXM/lib/Xt
XMINCPATH = -I/usr/lib/DXM/lib
XLIBPATH = -L/usr/lib
XTLIBPATH = -L/usr/lib/DXM/lib/Xt
XMLIBPATH = -L/usr/lib/DXM/lib/Xm
If you have an alternate motif setup, just make sure that XINCPATH and
XTLIBPATH point to the motif versions.
Also, check today's grass-u mail for a message from Amit about strdup,
which doesn't exist under Ultrix - you'll need the revised strings
code off the moon.
Good luck! Thanks to Jim Farley at Arkansas and Kurt Buehler at CERL
for helping to figure all this out.
-kenn
| Kenn Gardels Tel +01 (510) 642-9205 Fax +01 (510) 643-5571 |
| CEDR - 390 Wurster Hall Internet gardels@ced.berkeley.edu |
| University of California Bitnet gardels@UCBCED |
| Berkeley, CA 94720 |
