In response to:
> > 2. Can I run a class of 12 on grass? We have pc xemulators
> > running in our lab and I'd like to run a grass session
> > off our sun for their practicals.
> Yes - I have only had three at a time running, but the speed limiting
> factor was definitely the students not the software.
This is another item that keeps getting conflicting coverage. Simon, do
you just circumvent the GRASS anti-concurrent-user locking mechanism by
brute force, or is there a more elegant means that you might share -- I'm
supposed to be setting up a lab here too, on an existing 486 base.
I don't think the non-concurrent use feature is meant here. I simply give
each student his/her own mapset within the same location. Maps used
in the exercises all come from mapset PERMANENT.
If it's feasible to have a class of 12 on a single host depends on:
1) the processing power of the host;
2) the amount of data that needs to be processed by the individual
users, i.e. the number of cells in the region they are to use (assuming
raster analyses).
Raymond
