Greetings future XGRASSers,
Warning: translation table syntax error: Unknown keysym name: osfHelp
Warning: ... found while parsing ' <Key>osfHelp:
ManagerGadgetHelp() '
etc
I received several suggestions to copy /usr/openwin/lib/XKeysymDB to
/usr/lib/X11/XKeysymDB.There was not an "X11" directory in /usr/lib so I created one and
copied
the XKeysymDB file to it, but I am still getting the same errors.
One suggestion was that I set my path to find the Motif libraries
first,
but I don't have Motif. I was told that Motif is only needed to
compile
XGRASS, not to run it. That's the reason I pulled down the binary
version
instead of the source code. Is this correct?
Any other suggestions would be greatly appreciated.
Brent Stinson
brent@mishell.usda.msu.edu
My understanding is that the openwindows XKeysymDB will not work, you
want the OSFmotif key mappings. I used the XKeysymDB that's in the
xgrass source directories ($GIS/src/xgrass). If you've only downloaded
the binaries, I've put a copy of the XKeysymDB in grass/incoming at
max.cecer.army.mil. I believe this file MUST be placed in
/usr/lib/X11 because the static binaries have Motif embedded within
them and they are looking explicitly for /usr/lib/X11/XKeysymDB.
(You can check this by issuing the command:
strings xg* | grep XKeysymDB
in the directory where the xgrass binary executables reside.)
Changing your path won't help you in this case.
I hope this helps...
Andrew Hertz
hertz@geog.psu.edu
