When I try The Manage tool under Display under xgrass I get the following
message
"/grass4.1/xgrass/grass4.1/etc/xclip/d.mon", line 37:
<Illegal help data [04.wind.mgmt/04.02.mng.frm]> at or near """
How should I try to resolve that problem.
Nalneesh gaur
message
"/grass4.1/xgrass/grass4.1/etc/xclip/d.mon", line37:
Nalneesh gaur
I solved the problem by deleting the offending line in the xclip/d.mon
file. This rendered the help button nonfunctional but the xgen interface
to d.mon worked other than that. The problem is that to get all of xgrass
working you have to do this for everyone of the xclip/* files because
they all have the same reference to a help widget that doesn't work.
I hope the workaround helpsm but a working help widget would be better
solution.
Doug Dunlop
Earth-Observations Lab / Institute for Space and Terrestrial Science
