Hey all, I just checked out from cvs, and typed 'ant' and 'ant compile'
and got the following errors:
Buildfile: build.xml
compile:
[delete] Deleting directory C:\cygwin\home\Chris\geonetwork\.build
[mkdir] Created dir: C:\cygwin\home\Chris\geonetwork\.build
[javac] Compiling 93 source files to
[javac]
C:\cygwin\home\Chris\geonetwork\src\org\fao\geonet\apps\setup\Setup.java:11:
package org.fao.geonet.util does not exist
[javac] import org.fao.geonet.util.*;
[javac] ^
[javac]
C:\cygwin\home\Chris\geonetwork\src\org\fao\geonet\apps\setup\Setup.java:114:
cannot resolve symbol
[javac] symbol : class McKoiDB
[javac] location: class org.fao.geonet.apps.setup.Setup
[javac] private McKoiDB setupMcKoi(String installDir, Element
jdbc) throws Exception
[javac] ^
[javac]
C:\cygwin\home\Chris\geonetwork\src\org\fao\geonet\apps\setup\Setup.java:63:
[javac] McKoiDB mcKoiDB = setupMcKoi(installDir, jdbc);
[javac] ^
[javac]
C:\cygwin\home\Chris\geonetwork\src\org\fao\geonet\apps\setup\Setup.java:126:
[javac] McKoiDB mcKoi = new McKoiDB();
[javac] ^
[javac]
[javac] ^
[javac] Note:
C:\cygwin\home\Chris\geonetwork\src\org\fao\geonet\services\util\z3950\GNSearchTask.java
uses or overrides a deprecated API.
[javac] Note: Recompile with -deprecation for details.
[javac] 5 errors
Is there some class that wasn't committed?
thanks,
Chris
