Hey guys, just downloaded the beta1 of 2.0. It looks great, and seems
to be a lot more responsive than the last version.
I'm looking to set up a little demo Zambian SDI with GeoNetwork, and can
probably put in some time to help out, at least in documentation.
First problem is that I can't seem to find a button for intermap?
There's the little animated gif on intereactive maps, but clicking on
it seems to do nothing. Is it just not supported yet?
I tried out Jetty and the first time got an error about not being able
to remove the log file - might be nice to just supress that warning
message. Then I got an exception for mckoi - 'Journal file already
exists'. Turns out it was because I was already running geonetwork in
tomcat. But is there a good reason why you couldn't have both tomcat
and jetty running? Not that you'd ever really want to, but it just
seems like both should be able to access the same database.
What's the roadmap for the next few months of Geonetwork? If you're
looking at GeoServer integration I can probably help out on that front.
I'm planning on just doing most stuff by hand, but we could fairly
easily make an installer that includes both GeoServer and GeoNetwork.
I probably won't have time, but it'd be a very cool feature if when you
uploaded a new shapefile it became available in WMS/WFS with GeoServer.
It shouldn't be all that hard to hack it in, just rewrite the gs
config file or send a java object across the wire. Then from
geonetwork you could either download the file or view it on intermap,
or access through wfs with udig.
Another cool feature would be for udig to connect to the geonetwork
catalog directly.
The documentation seems to be a bit sparse - would you guys be
interested in a wiki for documentation on codehaus? And you could make
use of their bug tracker as well. Both could help open up what's going
on to outsiders, as it's still pretty opaque. James can probably
arrange this, and I'd be happy to put up my findings as I get to know
the software there. Questions like how to change the colors and the
images so I can make it geared towards a Zambian SDI, for example.
best regards,
Chris
This mail sent through IMP: https://webmail.limegroup.com/
