[Geoserver-users] problem GWC seed - wms data security
Ive searched but not found a solution to our problem,
We have a couple of data security rules for some specific layers, this prevent us from seeding the layers. We are well aware of the problem with security and caching but the gwc service is protected and all our request goes through the wms and with direct integration. Before we could preseed the layers and then recreate the rules but now we have to update the layers on the fly so we really need a solution.
If we try to seed a layer with an rule in data security it logs : Cannot access layer as anonymous
We have tried to put a http username parameter in webcachexml without success. Have also tried to temporary gave anonymous read access to the layer. Nothing works.
Can anyone help with a solution or workaround for this?
Best Regards,
Mike
On Wed, Jul 8, 2015 at 12:18 PM, Mikael Karlsson <mikael.karlsson@anonymised.com
Hmm.. I believe the GWC integration should record the Spring Authentication
object used when issuing the
seed request, and feed it into the seeding threads.
Assuming that is the right solution, some coding would be needed to make it
work
GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
It sounds logical. Feel like more people should come across this problem, no one managed to winkle a workaround for it?
If you can think of any possibility that might fix it without changing the code, I’m happy to try it.
Thanks
On Wed, Jul 8, 2015 at 12:18 PM, Mikael Karlsson <mikael.karlsson@…7138…> wrote:
Hmm… I believe the GWC integration should record the Spring Authentication object used when issuing the
Assuming that is the right solution, some coding would be needed to make it work
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jul 8, 2015 at 1:39 PM, Mikael Karlsson <mikael.karlsson@anonymised.com>
I don't think a workaround is possible, the threads doing the seeding are
completely isolated from the request cycles, you either
pass some information explicitly, or it cannot get there.
The change per se should not be too hard, but as usual, a very small
portion of the community is willing/able
to contribute a change, or to sponsor one via commercial support.
Ing. Andrea Aime
@geowolf
Technical Lead
Typical!
Maybe have to look for an alternate way to handle the authentication on the layers then, maybe a front proxy.
But now I just read about geofence, is it possible to maybe make this work with rules in the plugin? And delete the data security rules.
Best regards
On Wed, Jul 8, 2015 at 1:39 PM, Mikael Karlsson <mikael.karlsson@…7138…> wrote:
I don’t think a workaround is possible, the threads doing the seeding are completely isolated from the request cycles, you either
The change per se should not be too hard, but as usual, a very small portion of the community is willing/able
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jul 8, 2015 at 2:02 PM, Mikael Karlsson <mikael.karlsson@anonymised.com>
wrote:
Typical!
Writing a auth proxy is likely more work, in the long run, than passing
around the auth in GWC, but yes, it's a way.
The GeoShield project a few years ago was acting as a proxy, then they
switched to using the internal
security engine the same way GeoFence does, and they observed a significant
speedup, the proxy overhead
was higher than the time it took to run the WMS requests... since you are
talking about cached tiles instead,
beware of how much slowdown this approach might add.
We also have a little write-up on why we chose to invest on internal
security integration, instead of using
security proxies: http://demo.geo-solutions.it/share/securing_geoserver.pdf
Ah right, so as an option you could write, and plugin, your own
implementation of ResourceAccessManager (it's the interface
called when checking who can do what):
GeoFence just drives the same GeoServer security subsystem as the internal
security, it's just using it fully instead of 30% of its abilities.
So, changing to it won't achieve anything
Ing. Andrea Aime
@geowolf
Technical Lead
geowolf wrote
On Wed, Jul 8, 2015 at 1:39 PM, Mikael Karlsson &lt;
mikael.karlsson@
&gt;
3 years later, and I believe that we have a simple work-around for this
problem that still exists in GeoServer/GeoWebCache.
As a brief recap, if a GS layer is secured under menu item Security > Data,
then when a seeding task is initiated in GWC, the following error is logged
in GS:
Cannot access layer XYZ as anonymous
As Andrea mentions above, this is because the Spring Authentication object
is not fed into the seeding threads. This can be solved by 3 lines of code
in
https://github.com/GeoWebCache/geowebcache/blob/master/geowebcache/rest/src/main/java/org/geowebcache/rest/service/FormService.java#L225:
Authentication authentication =
SecurityContextHolder.getContext().getAuthentication();
SecurityContextHolder.setStrategyName(SecurityContextHolder.MODE_INHERITABLETHREADLOCAL);
SecurityContextHolder.getContext().setAuthentication(authentication);
But there's an even easier, non-code solution, and that is to insert the
following bean into geoserver/WEB-INF/dispatcher-servlet.xml, which
currently does not have any beans:
<bean
class="org.springframework.beans.factory.config.MethodInvokingFactoryBean">
<property name="targetClass"
value="org.springframework.security.core.context.SecurityContextHolder" />
<property name="targetMethod" value="setStrategyName" />
<property name="arguments" value="MODE_INHERITABLETHREADLOCAL" />
</bean>
We have tested this in production, and if you initiate the seeding task
while logged in as (or POST with the credentials of) a user with access to
the layer, this Authentication object will be copied into the seeding
threads, and it works 100% correctly.
I really hope this helps someone else. My company, AfriGIS, has spent many
hours looking for a solution.
Regards
Peter Smythe
AfriGIS
South Africa
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
mikael.karlsson@
&gt;
in GS:
in
<bean
</bean>
Regards
Peter Smythe
AfriGIS
South Africa
yes, that seems like a good approach (both, I like the spring one better)
GeoServer developers are normally too busy to handle patches in this format though, the way to contribute to the code is
explained here:
https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md
It’s basically the same rules followed by core developers (e.g., if we had to pick up your patch, we’d still
have to create a pull request and write a test for it before merging the change)
Best regards
On Tue, Jul 3, 2018 at 4:29 PM, PeterSm <gs@anonymised.com> wrote:
mikael.karlsson@
in GS:
in
But there’s an even easier, non-code solution, and that is to insert the
Regards
Peter Smythe
AfriGIS
South Africa
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.com.382…sourceforge.net
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
