On Tue, Feb 3, 2015 at 10:40 AM, Giuseppe Falcone <
falcone.giuseppe@anonymised.com> wrote:
Hi everyone,
I have a geoserver 2.2 installation. I added a new store as WMS connection
from another map server because I am interested in a raster layer of that
server.
I view this layer correctly, but if I added it into a layer group (with
vector layer) I get the following error:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM "
http://192.168.11.22:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1" > <ServiceException>
The requested Style can not be used with this layer. The style
specifies an attribute of geom and the layer is: MY_STORE:ortofoto
</ServiceException></ServiceExceptionReport>
What is this error?
Did you try to assign a different style to the wms layer? They normally
work against the built-in "raster" style, we don't
support cascading a local style onto the remote server.
GeoSolutions for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
