Hi, I a m using Geoserver + Openlayers.
I am testing filters.
If i have thsi filter for a WFS layer :
<Filter><Beyond><PropertyName>the_geom</PropertyName><gml:Point srsName="EPSG:2154">
<gml:coordinates>592681,2440367</gml:coordinates></gml:Point><Distance units="m">1000</Distance>
</Beyond></Filter>
everything is fine.
IF I change the request for a WMS layer, I get
org.vfny.geoserver.ServiceException: org.xml.sax.SAXException: Attempted to con
truct illegal filter - I dont understand the tag: gml:Point. HINT: tags are case
sensitive!
I have tried differnet requests, getting the gml: part oout, no luck.
Has anybody a clue ?
Cordialement
Bernard Jousse (bjousse@anonymised.com)
06 77 15 69 44
hmmm try declaring the ogc namespace in the <Filter> element like this:
<Filter xmlns=%22http://www.opengis.net/ogc%22…
(note: %22 accounts for the http encoded value of the double quote character)
I guess that'd do the trick. Write back if not, I'll try to find out what's
happening
cheers,
Gabriel
units="m">1000</Distance> </Beyond></Filter>
everything is fine.
con truct illegal filter - I dont understand the tag: gml:Point. HINT:
tags are case sensitive!
Well, now Geooserver does not complain. I just have no data selected in WMS.
Might be the way I give the distance.
character)
View this message in context: http://www.nabble.com/WMS-Spatial-request-tp14791850p14796530.html
Nope, I can confirm it's a bug with the shapefile renderer (you're using
shapefiles as your data source, right?).
If I run the following request with the properly parseable filter against a demo server we have:
http://geo.openplans.org:8080/geoserver/wms?bbox=-130,24,-66,50&styles=population&Format=image/png&request=GetMap&layers=topp:states&width=550&height=250&srs=EPSG:4326&filter=<Filter%20xmlns="http://www.opengis.net/ogc"%20xmlns:gml="http://www.opengis.net/gml"><Beyond><PropertyName>the_geom</PropertyName><gml:Point%20srsName="EPSG:2154"><gml:coordinates>-106,39</gml:coordinates></gml:Point><Distance>0.5</Distance></Beyond></Filter>
the result is an empty map. If I run the same request on GeoServer trunk
the result is correct instead (all the states besides Colorado). This means there is some bug in the interpretation of a beyond filter that has been fixed on geotools trunk only (geotools being the library we
use for data access, rendering and so on).
I'll investigate, thanks for reporting.
http://jira.codehaus.org/browse/GEOS-1667
Yes, I work with shapes. I'll try with another filter (DWITHIN probably)
ASAP. As long as I can run my next demo, I am not in a hurry...
View this message in context: http://www.nabble.com/WMS-Spatial-request-tp14791850p14798521.html
Well, if you need that filter to work, you can also dump all of your
data into a postgis database, there it should work fine.
Is this just BEYOND and DWITHIN, or could I use an Intersects against a
Polygon ?
View this message in context: http://www.nabble.com/WMS-Spatial-request-tp14791850p14799324.html
Polygon ?
I have no idea about the nature of the bug, still haven't looked into
it, so I don't know what spatial predicates you can or cannot use
successfully. If you use a postgis database you'll be able to use
them all.
Or, you can switch back to geoserver 1.5.x for the time being,
shapefile rendering is visibly slower but at least the bug it's
not there.
Hi Bernard,
Which version of 1.6.x are you working with... i thought i fixed this
issue of having to declare the filter namespace... perhaps not.
happening
cheers,
Gabriel
everything is fine.
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Geoserver-users mailing list
!DSPAM:4007,478a8cac99871637810514!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Hi Justin,
I just downloaded the 1.6.0 RC-2 about 2 weeks ago. Hi Kustin,
Justin Deoliveira a écrit :
Hi Bernard,
I guess that'd do the trick. Write back if not, I'll try to find out what's happening
cheers,
Gabriel
everything is fine.
Cordialement
06 77 15 69 44
FYI I tested DWHITIN, BEYOND, WITHIN + polygon , INTERSECTS + POINT : none
gives answers..
bjousse wrote:
Hi Justin,
View this message in context: http://www.nabble.com/WMS-Spatial-request-tp14791850p14812187.html
bjousse ha scritto:
gives answers..
Yep, I confirmed that. I think I have fixed the issue.
Can you download http://jira.codehaus.org/secure/attachment/31879/gt2-shapefile-renderer-2.4-SNAPSHOT.jar,
paste it into your geoserver 1.6.0-Rc2 web-inf/lib
directory (it will replace an existing one) and see if it works for you?
OK, I tried different requests in the same map as WMS and superimposed the sams as WFS
As long as I dont do DWITHIN or BEYOND, everything fits.
If I do a Beyond or a DWITHIN, it looks like the WMS distance ichanges with the zoom level. I superimposed the same request in WFS and WMS, When I zomm out, i get less featues (points) in WFS than in WMS, when I zoom in, I get more. the common points ovelap perfectly.....
I have two other point layers WMS/WFS in this map, but they have no request on them, and I do not see this effect.
screen shots available if you want..
Andrea Aime a écrit :
bjousse ha scritto:
gives answers..
Cordialement
Right, managed to reproduce it as well. Should be fixed with this new jar, can you test it?
http://jira.codehaus.org/secure/attachment/31905/gt2-shapefile-renderer-2.4-SNAPSHOT.jar
Sorry, still the same, too many points or not enough depending on the zoom
ratio
View this message in context: http://www.nabble.com/WMS-Spatial-request-tp14791850p14886379.html
ratio
Strange, I've tried it with different layers and it seems to be working
for me... hmm... rc3 is about to go out and I cannot stop it anymore, so
let's do this: you try rc3, if you can reproduce again, open a jira
issue with the data and the filter you're using so that I can see what's
off.
OK. Thanks for all the time spent
ratio
off.
Cordialement
