I would welcome an explanation of the 3D attributes returned by g.region.
Consider the following:
gs.run_command("g.region", b=0, t=100, tbres=20, rows=150, cols=135)
gs.run_command("g.region", flags="3p")
It returns:
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 220750
south: 220000
west: 638300
east: 639000
top: 100.00000000
bottom: 0.00000000
nsres: 5
nsres3: 1
ewres: 5.18518519
ewres3: 1
tbres: 20
rows: 150
rows3: 750
cols: 135
cols3: 700
depths: 5
cells: 20250
cells3: 2625000
What are rows3, cols3 and cells3?
rows3 seems to be rows * depths, but cols3 is not cols * depths.
Also, I would expect cells3 to be the number of 3D cells, but it is not. In the case above, the number of 3D cells should be depths*rows*cols, or 20*150*135=405000, but instead it is depths*rows3*cols3.
What is going on here? Is the 3D region size and resolution independent from the 2D region? If so, it is rather unexpected and should be better documented.
