Action from popup - select points within a selected polygon
with this sql query i can get all the points within a polygon (gid = 1652):
SELECT
	polygon.gid,
	points.*
	FROM polygon
	LEFT JOIN points
	ON st_contains(polygon.the_geom, points.the_geom)
	WHERE polygon.gid = 1652
i’ am trying to adapt the action_name = ‘closest_fire_station’ like this:
    datasource:= format('
		WITH tmp_polygon AS (
            SELECT the_geom FROM polygon WHERE gid = ''%1$s''
		SELECT
			points.*,
			LEFT JOIN points
			ON st_contains(polygon.the_geom, points.the_geom),
			''mensagem'' AS message
		FROM
			tmp_polygon polygon
but without success
can someone help me please?
thanks in advance
	        SELECT
            	%1$s AS gid,
				''message'' AS message,
            	polygon.the_geom AS the_geom
            FROM polygon
            WHERE gid = %1$s
What do you mean with your latest message ? Can you give some more context ?
but without success
What does it give you ? Does your query returns something ? Is-there an error message ?
Just a note about the new OpenLayers style which must be used : Fixing action style for new OpenLayers by rldhont · Pull Request #262 · 3liz/lizmap-documentation · GitHub
hi @etrimaille
i can solve my problem with the code above inside lizmap_get_data function
it’s not enough, the action icon doesn´t appear on toolbar popup
i can confirm, the action module is ok on 3.8!
thanks
