assigning colors to raster maps
Hello,
  I am having difficulties assigning colors to a raster map with
  44 different categories. I am using d.colors and changing the
  categories one by one to get the shading I want. The problem
  is that categories seem to change regardless of whether I change
  them or not. Clearly I am doing something wrong. I would
  appreciate any suggestions or others ideas.
  Thank you in advance.
  Pamela Phillips
  Center for Space Research, Imaging Lab
  University of Texas, Austin
  pamela@magellan.ae.utexas.edu
1. Try commands d.colormode fixed / d.colormode float.
  There are a couple of things that you might consider!
   making color assignments.
3. Try p.colors for making color assignments based on the colors
   that your painter supports.
Good Luck,
-phil
Phillip L. Chaney Center for Advanced Spatial Technologies
Research Specialist National Center for Resource Innovations-SW
      12 Ozark Hall
      University of Arkansas
      Fayetteville, Arkansas 72701
      Phone: (501) 575-6159
                    (501) 575-4575
                        FAX: (501) 575-3846
      E-mail: phil@spock.uark.edu
