Attempt at compiling the SDTS utilities
Ouch!
Michael:
I know we exchanged email sometime before and I duidn't follow through
very well. Is there any chance you could send me an SDTS dataset you
are having trouble with and let me try to figure out what's going on?
(I'm not involved with GRASS anymore, really, but if I can fix this
I'd like to try.)
-David Stigberg
In message <199703270203.TAA08489@alb-co-r.> writes:
> Hello,
> We are attempting to compile the SDTS utilities under Solaris
> 2.5 and we ran into problems. We first wrote the gmake4.1 file
> to begin the process. The following is the printout of our
> attempt.
I had the same problem. I fixed it by going into the files with the errors and
commenting out the declarations for div_t and ldiv_t. These are already
declared somewhere in the system files. I have to warn you though, I have not
been very successful at creating GRASS files from SDTS format. There is a bug
in either these modules or the ARC/INFO modules that create SDTS files.
> rm -f OBJ.sun4/a_toe.o
> gcc -ansi -O -I./f123inc -DFIPS_BSD -I/grass/4.1/src/include -c
> a_toe.c
> In file included from ./f123inc/stc123.h:385,
> from a_toe.c:48:
> ../f123inc/fips_bsd.h:7: conflicting types for `div_t'
> /opt/gnu/lib/gcc-lib/sparc-sun-solaris2.4/2.6.3/include/stdlib.h:
> 27: previous declaration of `d
> iv_t'
> ../f123inc/fips_bsd.h:9: conflicting types for `ldiv_t'
> 32: previous declaration of `l
> div_t'
> ../f123inc/fips_bsd.h:15: conflicting types for `ldiv'
> 108: previous declaration of `
> ldiv'
> *** Error code 1
> make: Fatal error: Command failed for target `OBJ.sun4/a_toe.o'
> Current working directory
> /grass/4.1/src.contrib/CERL/SDTS/libes/fips123
> *** Error code 1
> make: Fatal error: Command failed for target `all'
> alb-co-r%
Michael Hanratty Phone: (612) 627-4590
St. Anthony Falls Laboratory Fax: (612) 627-4609
Dept. of Civil Engineering
University of Minnesota
Mississippi River @ 3rd Ave. SE
Minneapolis, MN 55414
David Stigberg x7631, x4420
