How about simply using awk to read the numbers into two separate temporary
files, then using paste to put them together. This will do what you seem to
be asking for if both input files have the same number of lines.awk '{ printf ("%f\t%f\n", $1,$2) }' input_file_1 > temp_1
awk '{ printf ("%f\t%f\n", $3,$4) }' input_file_2 > temp_2
paste temp_1 temp_2 > output_fileThis will create an output file containing the first two fields from
input_fiel_1 and the third and fourth fields from input_file_2 on each line,
separated by tabs. Of course, you can edit this to reflect the proper
input fields, separators, etc.
Ah! Now I see. paste nee' lam. Thanks Mike.
_________________________________
Dr Simon Cox |
Department of Earth Sciences |
Monash University |
Clayton Vic 3168 |
Australia |
Phone (03) 565 5762 |
Fax (03) 565 5062 |
________________________________|
