Hi every one
I am working on moving the input queries into the C++ code.
The reason for doing this work is:
On the C file:
- Includes what we call a driver header is linked as C
- The driver headers are very similar to each other
- the static
processwithin each C file example are very similar- opens the connection with postgres
- reads the data, (edges sql, restrictions_sql, etc and any array that is on the query)
- all of these reading is done on the C code which interacts with Postgres, (which is written in C.)
- Suppose, for simplifying this description, that the data takes
xMB in memory
- calls the
pgr_do_functiondefined on the driver - gets the results
- closes the connection with postgres
On the driver C++ file:
- code is written in C++
- Drivers are very similar within each other.
- Convert C arrays to C++ containers
- Now memory size is 2x + container overhead
- Builds the boost graph
- Now memory size is 3x + container overhead
- None of this code interacts with Postgres
The ideal situation:
- Build the boost graph as the data is read.
- Have C++ templates on the drivers
- Being so similar that can be done
General steps to reach the ideal situation
- Be able to read the postgres data on the C++ code
- Create the templates
- Build the boost graphs based on the templates needs
Current work
Right now I am working on first step which is, in rough terms, moving the reading of the data to C++, but without moving yet the arrays, only the reading of the SQL queries.
The sketch of the C & C++ driver files for the first step:
On the C file:
headerlinked as C- The driver headers are very similar to each other
- the static
processwithin each C file will still be very similar- opens the connection with postgres
- calls the
- Drivers will still be very similar within each other.
- C++ code will interact with postgres
- Read the data directly into C++ containers
- Two kinds of data
- Working on: Data that comes from the inner SQL queries
- Data that comes from arrays
- All of these reading will be do with C++ code
- Now the reading into C++ container takes
xMB in memory
- Two kinds of data
Right now I am working on first step: Be able to read the postgres data from the inner queries on the C++ code
