Hi @pedro-cf welcome if discourse.
This forum is not an issue tracker, to report an issue see website / jira.
Any idea what is going on? Is the folder not created or writable or something?
Searching docker I do not see the part that copies the demo directory any more?!?
The docker image changed to using a tomcat base recently and needs more testing and feedback.
Testing normal startup
docker pull docker.osgeo.org/geoserver:2.27.x
docker run -it -p8080:8080 \
--mount type=bind,src=/Users/jgarnett/dev/geoserver/data2,target=/opt/geoserver_data \
docker.osgeo.org/geoserver:2.26.x
Starts up:
18 Nov 17:50:56 CONFIG [geoserver.logging] - Log4j 2 configuration set to DEFAULT_LOGGING.xml
18 Nov 17:50:59 CONFIG [org.geoserver] - GeoServer configuration lock is enabled
18 Nov 17:51:00 CONFIG [org.geoserver] - Loading catalog /opt/geoserver_data
The data2 folder is populated with release data directory so that is good.
Testing SKIP_DEMO_DATA startup
rm -r Users/jgarnett/dev/geoserver/data/*
--env SKIP_DEMO_DATA="true" \
Starts up with empty folder:
17:56:09 CONFIG [geoserver.logging] - Logging policy: Log4J2
17:56:09 WARN [geoserver.logging] - Could not find GeoServer logging.xml (or old services.xml) settings for logging
17:56:13 CONFIG [org.geoserver] - GeoServer configuration lock is enabled
17:56:13 CONFIG [org.geoserver] - Loading catalog /opt/geoserver_data
17:56:13 WARN [org.geoserver] - No 'workspaces' directory found, unable to load any stores.
17:56:13 CONFIG [org.geoserver] - Read catalog in 14.18 ms
Trying out your example:
curl -u admin:geoserver \
--request POST \
--url http://localhost:8080/geoserver/rest/workspaces \
--header 'Content-Type: application/xml' \
--data '
<workspace>
<name>test</name>
</workspace>
The problem appears to be a security issue, checking security/rest.properties which allows access to the REST API and no roles have been setup yet.
Filling in the example from release data directory allows the workspace to be created:
# Default REST security configuration.
# By default this configuration locks down every rest call. The following is an example of a more
# lax configuration in which read only (GET) access is allowed anonymously:
#/**;GET=IS_AUTHENTICATED_ANONYMOUSLY
#/**;POST,DELETE,PUT=ADMIN
# The following is an example of a configuration that could be used with the restconfig plugin in
# which only configuration in a specific workspace is restricted:
#/rest/workspaces/topp*;GET=ADMIN
#/rest/workspaces/topp/**;GET=ADMIN
/**;GET=ADMIN
As indicated the default configuration locks down REST API access only allowing the admin console to be used.
To allow the use of the REST API a security/rest.properties policy needs to be set.
