I’d like to work on this issue (#975) to fix the CI problem where tests for deprecated modules are still being run. Before I start, could you please clarify:
What criteria should be used to identify deprecated modules in the testsuite?
Where should tests be filtered out — in the testsuite discovery logic or in the CI configuration?
