I'm new to grass, but experienced in UNIX/Linux. Any pointers for solving
this problem?
RH 6.1, gnome, grass install from grass5beta5_linuxbin_tar.gz on a 233MHz
IBM thinkpad, 64Mb RAM
Installed without error, grass starts up ok (using spearfish data),
tcltkgrass starts ok
but I can't get a monitor window to open - either from tcltkgrass or
command line in grass.
From command line:
'd.mon start=x' yields: "can not allocate any read/write color cells"
subsequent '^C' yields: "Problem selecting x0. Will try once more"
one more '^C' exits to grass prompt.
from tcltkgrass toolbar:
an attempt to start monitor yields a d.mon window containing
the message "can not allocate any read/write color cells" and prevents any
other
action from the tcltkgrass toolbar until the d.mon window is dismissed.
Glen L. Gunsalus, Ph.D. Telephone: (212) 327-8757
The Population Council Facsimile: (212) 327-8839,-7678
1230 York Avenue E-Mail: glen@popcbr.rockefeller.edu
New York, NY 10021 G-Gunsalus@popcbr.rockefeller.edu
Glen,
I had the same problem with RH 6.0 & Gnome. I fixed it by switching my
console from bash to C before starting X. It also seems to work by launching
GRASS from a C shell in a terminal window.
Hope that works for you too.
Patrick Barabe
Center for Applied Spatial Analysis
The University of Arizona
Tucson, AZ
http://www.casa.arizona.edu
this problem?
>From command line:
other
Glen and Patrick,
you may take a look at GRASS FAQ:
http://www.geog.uni-hannover.de/grass/faq/
-> Frequently asked questions:
-> d.mon problems: Error: "cannot allocate any read/write color cells" .
Hope this helps
Markus Neteler
On Tue, Mar 07, 2000 at 03:34:26PM -0700, Patrick Barabe wrote:
: en
X-Listprocessor-Version: 7.2 -- ListProcessor by CREN
Status: O
Content-Length: 1476
Lines: 45
Glen,
Patrick Barabe
Tucson, AZ
> this problem?
> >From command line:
> other
