Color and grayscale display
I am trying to register some 256-color aerial photos to grayscale
orthophotos using the i.ortho.photo routines. Registration is difficult
because of the poor color and grayscale representation of the images in
GRASS-Linux. I have tried using the float colormode. This improves the
greyscale image but not the color image. I have also tried using the 24-bit
x-driver, but that does not result in any better color or greyscale
representation. Are there any other techniques which might give better
resuilts? Thank you for your help.
Note: I can export the images from GRASS using r.out.ppm and display them
with xv in Linux, and the color is improved. Is there some internal limit
in GRASS that does not allow display of all 256 colors?
Jim Schmidt
USDA Forest Service
Sonora, California
Jim Schmidt
USDA Forest Service
Sonora, California
perhaps you are running X in 8 bit color and running out of colors to
allocate. Have you tried 16 or 24 bit mode (startx -- -bpp 16 (or 24)
) to see if the display looks better?
Jim Schmidt
USDA Forest Service
Sonora, California
I did use startx -- -bpp 24, but it did not seem to result in a better
color or grey scale representation. I will check on that again, however.
Thanks for the advice.
Jim Schmidt
