Hi all
in the geoserver-devel forum we are discussing removal of a few community modules.
Removal is based on absence of an interested party that can develop the module further, as well as lack of activity/funding on it for a while.
Here is a list of modules that are in the community section, which do not seem to have any action, value, or chance of being resurrected anytime soon:
- app-schema/webservice-test: run only with custom profiles (oddly, both “webservice" and "app-schema” do). It does not even start to build, depends on the gone gt-webservice-test module.
- gwc-distributed: containing just a Spring context and some dependencies, enables the Hazelcast distributed in memory tile cache. Anyone using it?
- imagemap, enables the HTML image map output format. I guess nobody today uses HTML image maps in cartography, but if you do, please let me know.
- jdbc-metrics seems to collect statistics about queries in JDBCFeatureReader. On one side, it seems like a useful tool to track time actually spent talking to the database, on the other, it has no documentation has has seen to action for the past 7 years. Anyone using it, or that would be interested in writing a bit of documentation for it?
- monitor-hibernate provides database storage for the monitoring subsystem. Unmaintained, based on the dead Google code genericdao framework, and afflicted by using primary keys in a log table (insertions become slower and slower), it probably deserves some final rest, a suitable replacement would be a rewrite, not a few small fixes.
- pgraster despite the name it’s an easy to use UI on top of the no longer existing gt-imagemosaicjdbc. This one already has a removal PR.
- saml is gone already, but its assembly descriptor survived and should also be removed.
- wps-sextante is based on the Sextante java libraries… which I cannot find any more. The version it depends onto has been released around 2012, the module received its last direct commit in 2015 (all others are mass refactors), has no documentation, Sextante for Java seems nowhere to be found…
- xslt is a WFS output format generator based on XSLT that was demoted to community in May 2023. Looks like nobody complained, I’d complete the job.
Regarding extensions, the following look like good candidates for demotion to community:
- h2 store, based on the old and unmaintained H2 v1.x. While we cannot get rid of it completely, as some modules keep on depending on it (e.g. the NetCDF store family), I’d make its availability as a vector store harder to get.
If you are using the module and can step up to revitalize it, or are interested in funding new development on it, please let us know soon.
Also mind, removal of a module is never permanent, we’ll make separate commits and getting one back is a matter of reverting it, as soon as someone active on the module shows up again.
Andrea Aime
Visit GeoSolutions Enterprise Support Services for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
