Hello GRASS-world,
following a quick and dirty compilation report of GRASS4.1 on
Linux.
(At first I want to apologize for my bad english)
OS: Linux SLS 1.02
Kernel: 99pl9
GRASS Version: GRASS 4.1
Hardware: Motherboard ASUS 486DX2 66
8 Mb RAM (not enough)
Micropolis 1598 1,2Gb
521 Mb ext2fs partition
Compiler: gcc 2.3.3
Libs: libc 4.3.3
Lex: gnu flex 2.3
Motif: Metrolink 1.2.2
The compilation failed on stage:
27.05.93 compilation of GRASS4.1
src/raster/r.binfer failed to link: symbol _yylineno undefined
usage in main.c, 2 occurences commented out
use of _yylineno not POSIX conform!
src/raster/r.combine problems to compile gis_lxcl.c
generated thru lex from gis_lxcl.l
this is a problem due to the differen-
ces of the gnu lex/flex and the
lex used by GRASS developers. The
gnu lex/flex has an implementation
of yywrap, so if you want the implementation
in GRASS you have to add #undef yywrap at the
beginning of gis_lxcl.l (between %{ .. })
A second error is based on the
implementation of yyinput. I
changed yyinput to input and it works, but not tested!
src/raster/r.mapcalc/r.polish conflict between definition of
malloc in pol.y and Linux.
Definition in pol.y deleted, got
a lot of warnings, so I have to test!
src/raster/r.wheight/inter you have to add #undef yywrap at the
src.alpha/imagery/i.ortho.photo/photo.2image zoom_box.c -> gis.faq step 11
src.alpha/imagery/i.ortho.photo/photo.2target zoom_box.c -> gis.faq
src.alpha/mapdev/v.cutter/table.c commented out all the text after line 513 until
#undef
Compiling XGRASS with Metrolinks Motif:
The behaviour of XGRASS is realy curious! I compiled the same code on IRIS
Indigos. It's running almost without problems (only coredumps sometimes from
xdigit).
compiler options used -O2 -m486 - D_NO_PROTO
src/xgrass/libes/bwimage.c line 93 - to few arguments to function 'exit'
was 'exit()' changed to 'exit(0)'
src/include/MatrixP.h #include <Xm/ManagerP.h> added
src/include/ClipP.h #include <Xm/PrimitiveP.h>
src/include/CaptionP.h #include <Xm/ManagerP.h> added
src/xgrass/libes/Xgi/Interact.c #include <Xm/PrimitiveP.h> added
body of XgInteractorActivate commented out, no solution!!
src/xgrass/libes/Xgi/Help.c macro MAX defined
src/xgrass/libes/Xgi/Matrix.c macro MIN defined
src/xgrass/menu/xc.error.c all accurences of zzlineno commented out or
zzlineno erased
src/xgrass/menu/xc.modify.c all accurences of zzlineno commented out or
zzlineno erased
src/xgrass/display/grammar.y third parameter in strtod deleted
src/xgrass/gridgadg.c brutally commented out the external declaration of atof
src/xgrass/display/main.c all occurences of yylineno commented out
src/xgrass/pixmap/PixEdit.c Zeile 1809 XtAddCallBack changed to XtAddCallBacks
Is this ok? It seems, as I have to learn to
work with Motif!
src/xgrass/pixmap/Pixmap.h Prototype PwPutImage: Xdisplay -> Display
missing ","'s
src/xgrass/pixmap/Pixmap.c Line 531 diffrences between prototype and function
PWPutImage
src/xgrass/xdigit/map_ask.c lines 79 und 80 too few arguments to function `strncmp'
strncmp changed into strcmp
the modules xgrass4.1 and xdigit are still not running.
xgrass4.1 has problems reading xgrass-menu.
xdigit crashes with an X-error. I debugged, very curious behavior in
xcolor.c and xpanel.c. Why this problems? The same code is running
on IRIS INDIGO's!
Compiling XDRIVER
XDRIVER - SWITCHER.C: there are two kind of prototypes in the Linux libraries:
BSD conform: setpgrp(par1, par2)
you have to define #undef __linux__ at the
beginning of SWITCHER.C
the better solution is to delete all parameters and
use setpgrp() !!!!!!
Here a summary from Grass4.1beta. I have not compiled this Grass4.1 programs until
today!
src.contrib/PURDUE compiled completely
src.contrib/CAST compiled completely
src.contrib/CERL/imagery/i.rvi.prediction failed
src.contrib/CERL/imagery/i.shape ok
src.contrib/CERL/misc/m.eigensystem PROCEDURE EXIT( .. ) missed
convert main.f via f2c into main.c
edit main.f and change all exit calls
into exit(0) or exit(1)
src.contrib/CERL/misc/m.regression compiled completely
src.contrib/CERL/raster/r.linear.regression compiled completely, but you have to
copy the programm to $GIS/bin manually
src.contrib/CERL/raster/r.ndvi.model compiled completely, but you have to
src.contrib/CERL/raster/r.rational.regression compiled completely, but you have to
src.contrib/CERL/raster/r.rvi failed to compile
src.contrib/CERL/raster/r.traj failed to compile, wrong path in Gmakefile
src.contrib/CERL/libes/projsupp compiled
src.contrib/CORPS/FLOOD compiled ok, but you have to
copy the programm to $GIS/bin manually. Use dire
ctory tutor!
src.contrib/COPRS/FLOOD/r.out.sites compiled ok
src.contrib/EPA/grass.ipw where is libipw.a ?
src.contrib/NMSU/WRAT
/ga remove ';' at end of include statement of ga.c
/wrat remove ';' at end of include statement of ta.c, runoff.c, cn.c
cs.c, da.c, ideal.c, intro.c, qp.c, qual.c, rout.c, upall.c
Compilation of RIM:
I have RIM compiled, it needed a little bit hacking, but it works. If
someone wants a report, please mail, but you have to wait a week or two,
if I will not forget to mail!
So long at a lot of fun!
Dipl. Geol. Andreas Holz email: asholz@cip.informatik.uni-erlangen.de
Institut fuer Geologie und Mineralogie
Schlossgarten 5
W-8520 Erlangen
GERMANY
