I'm trying to write a GRASS executable (called d.rast.PROJ), but I'm havin
g
trouble getting GRASS to recognize it. The directory is currently just a cop
y
of the .../src/display/d.rast directory & it compiles O.K. with gmake4.1. No
w
how do I get GRASS to know it exists?
The GRASS compilation README says to run the MAKELINKS script, but I don't
want to re-do all the links - I only want to add a link to my executable
(d.rast.PROJ).
Well, redoing all the links just takes up a bit of time, no other
resources. If you don't want to do it, there's a more direct way:
cd to $GISBASE/bin, get a directory listing (ls), choose any name
(I normally use v.trim because that's easy to type and comes last
in the listing) and type:
ln <v.trim> d.rast.PROJ
Also, make sure that your new binary is in one of the recognized
binary directories (e.g. $GISBASE/etc/bin/contrib/cmd)
(to be P.C., maybe you should type
ln $GISBASE/etc/front.end d.rast.PROJ
but since hard links are transitive, it's all the same)
Martin
