connectivity matrix from vect file
Date: Tue, 14 Apr 92 20:14:59 -0500
Message-Id: <9204150114.AA02865@clover.ecn.purdue.edu>
Sender: lists-owner@amber.cecer.army.mil
Reply-To: grassp-list@amber.cecer.army.mil
Precedence: Bulk
Subject: connectivity matrix from vect file
I want to form a connectivity matrix from a vector file:
an N x N symmetric matrix called C with non-zero entries
in C(i,j) when the area labeled with category i shares a border
with the area labeled with category j (assuming all areas
have unique labels). "Connected" means they share a line, not
just a node.
Looking over the structs for topology files, I don't believe that
this information is explicitly stored (correct me if I'm wrong).
Before I get too carried away, has anyone ever done this?
Seems simple: for (i=0;i<Plus_head.n_areas;++i)
                 for (j=0;j<P_area.n_lines;++j) {
                      /* must cross line j, returns adjacent category */
                      k=find_area_which_shares_line(i,j);
                      c[cat_of_area(i)][cat_of_area(k)]++;
If anyone knows a easy way to do this or can suggest
the best src program and/or library functions to use
as a starting point, I would be grateful for a short
reply in private email.
--Darrell
First off, in GRASS you index the line and areas from 1 to N, not 1 to N-1.
The key is that lines store which areas are to their left and to their right.
If you loop by areas as above, then you will get twice the number
of hits as you want, since each line would be tested twice.
The code you want is something like:
    struct Map_info *Map; /* returned from Vect_open_old() */
          /* level must be >= 2 */
    P_LINE *Line;
    for (i=1 ; i <= Map.n_lines ; ++i) /* for each line */
  Line = &(Plus_head.Line[i]); /* just set pointer */
  if (Line->left && Line->right) /* if it sits between 2 areas */
  { /* then get the attributes and update matrix */
      c[V2_area_att (Map, Line->left)][V2_area_att (Map, Line->right)]++;
  Dave Gerdes
  US Army Construction Engineering Research Lab
  Spatial Analysis & Systems Team
  dpgerdes@cerl.cecer.army.mil
  (217) 352-6511 x591
