Creating and Editing MapInfo tab file with multiple feature types in QGIS
in QGIS Is there any plugin available to combine layers with features with different geometry types(polygons, lines points etc.) and save into a single MapInfo tab file.
when the table’s structure is the very same, just export geometry type A first. Then type B → select as “export to” file the just created one with the features of type A. QGIS will ask you if you want to overwrite the layer or append features. select “Append”.
Thank you very much Meyerlor, the solution you suggested worked
