I’d like to share a problem I ran into with custom JavaScript files in Lizmap and a pattern that makes them more robust. Maybe it helps others, and maybe someone can say more about the root cause.
Setup
- Lizmap Web Client [Lizmap 3.10.0-rc.4-pre.11902], project configured with the Lizmap plugin targeting 3.10
- Several custom JS files in
media/js/<project>/(home button redirect, external links dock, Google Street View, theme name display) - Most of them follow the common pattern from the Lizmap JS examples:
js
lizMap.events.on({
uicreated: function () {
// add dock, bind click handlers, ...
Symptom
On macOS everything worked. On Windows 11 with Microsoft Edge, none of the custom features appeared. For example, the Home icon opened the Lizmap project list instead of our website. At first I suspected that Edge was not executing the JS. That was wrong: all project JS files were loaded correctly.
Analysis
The browser console showed this error during map initialization:
Uncaught (in promise) TypeError: Cannot read properties of null (reading 'w')
at initialize.setMap (assets/js/OpenLayers-2.13/OpenLayers.js)
at initialize.addLayer (assets/js/OpenLayers-2.13/OpenLayers.js)
at Object.completeInitialization (assets/js/map.js)
at assets/js/lizmap.js
My understanding of what happens:
- Lizmap initializes the map in a promise chain: load config, create the map, add layers (
completeInitialization), and only at the end triggeruicreated. - When a layer is added, OpenLayers 2 calls
map.getSize().w.getSize()returnsnullif the map container has no measurable size at that moment, for example because layout or CSS is not finished yet, or the tab is in the background. - The exception aborts the promise chain, so
uicreatedis never triggered. - Every custom script that waits for
uicreatedsilently does nothing.
Interestingly, the map itself was still displayed and usable. Only the legacy OpenLayers 2 part failed. So the custom scripts could have worked; they just never got the signal to start.
Whether the container has a size in time seems to depend on timing (browser engine, cache state, window size, display scaling). That would explain why it worked on one machine and not on another. I could reproduce the same error in a Chromium-based browser on macOS while the window was in the background.
Robust pattern
Instead of relying only on uicreated, I now start each script through a small helper. It runs the callback exactly once: on uicreated in the normal case, or as a fallback as soon as the map and the menu exist, if initialization aborted with an uncaught promise error or uicreated did not arrive within 10 seconds.
js
window.onLizmapReady = window.onLizmapReady || function (fn) {
var done = false;
var polling = false;
function run() {
if (done) { return; }
done = true;
try { fn(); } catch (e) { console.error('onLizmapReady callback failed:', e); }
function isReady() {
return !!(typeof lizMap !== 'undefined' && lizMap.mainLizmap &&
lizMap.mainLizmap.map && document.getElementById('mapmenu'));
function startFallback() {
if (done || polling) { return; }
polling = true;
var tries = 0;
var timer = setInterval(function () {
if (done || ++tries > 120) { clearInterval(timer); return; }
if (isReady()) { clearInterval(timer); run(); }
}, 250);
// Normal case
lizMap.events.on({ uicreated: run });
// Fallback 1: map initialization aborted with an uncaught promise error
window.addEventListener('unhandledrejection', function () { setTimeout(startFallback, 500); });
// Fallback 2: safety net if 'uicreated' never arrives
setTimeout(startFallback, 10000);
Usage: replace
js
lizMap.events.on({ uicreated: function () { ... } });
with
js
onLizmapReady(function () { ... });
Other events like dockopened or minidockclosed can stay as they are.
The helper is defined with window.onLizmapReady = window.onLizmapReady || ..., so each JS file can carry its own copy and still work independently, regardless of load order.
Simpler cases need no Lizmap event at all
For a Home button redirect, a delegated click handler on document level is enough. It works immediately:
js
(function () {
var target = 'https://www.example.org/';
var sel = '.nav-list .home a';
$(document).on('click', sel, function (e) {
e.preventDefault();
window.location.href = target;
To hide a menu entry, an injected CSS rule works without any event:
js
(function () {
var style = document.createElement('style');
style.appendChild(document.createTextNode('.nav-list .home { display: none !important; }'));
document.head.appendChild(style);
Additional notes
- If a script may run twice (for example
uicreatedplus a fallback, or the Google Maps API callback), add a guard against double initialization, e.g. check whether its dock element already exists. - Scripts that read the projection from
lizMap.map.projection.projCodedepend on the legacy OpenLayers 2 map.lizMap.mainLizmap.projectionis available on the current map.
Open questions
- Is this
getSize()null error duringcompleteInitializationa known issue, especially with 3.10? - Is there an official event or recommended way for custom JS that should not depend on a successful map initialization?
- The pattern makes custom scripts robust, but it does not fix the initialization error itself.
Thanks for any feedback!
