Hi there,
I am currently tasked with the integrating jCasbin(GitHub - casbin/jcasbin: An authorization library that supports access control models like ACL, RBAC, ABAC in Java) into Geoserver in order to use it for user authorization based on a central Casbin config file. The basic concept is to intercept incoming requests and validate against a given configuration. I followed the guide to implement an OWS service(Implementing a simple OWS service — GeoServer 2.27.x Developer Manual) and also looked at the “gs-kml” extension. My custom plugin compiles successfully but it is not recognized by Geoserver(v2.26.1)
My pom.xml looks like:
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<!-- set parent pom to community pom -->
<parent>
<groupId>org.geoserver</groupId>
<artifactId>community</artifactId>
<version>2.26.1</version>
<!-- change this to the proper GeoServer version -->
</parent>
<artifactId>CasbinInterceptorForGeoserver</artifactId>
<version>1.0</version>
<packaging>jar</packaging>
<name>Casbin Interceptor</name>
<properties>
<maven.compiler.source>17</maven.compiler.source>
<maven.compiler.target>17</maven.compiler.target>
</properties>
<!-- declare dependency on geoserver main -->
<dependencies>
<dependency>
<artifactId>gs-main</artifactId>
</dependency>
<dependency>
<artifactId>gs-wms</artifactId>
</dependency>
<dependency>
<groupId>org.casbin</groupId>
<artifactId>jcasbin</artifactId>
<version>1.79.0</version>
</dependency>
</dependencies>
<repositories>
<repository>
<snapshots>
<enabled>true</enabled>
</snapshots>
<id>osgeo</id>
<name>Osgeo Maven Repository</name>
<url>https://repo.osgeo.org/repository/Geoserver-releases/</url>
</repository>
</repositories>
<build>
<resources>
<resource>
<directory>src/main/resources</directory>
<includes>
<include>**/*</include>
</includes>
</resource>
</resources>
<plugins>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-compiler-plugin</artifactId>
<version>3.8.1</version>
<configuration>
<source>21</source>
<target>21</target>
</configuration>
</plugin>
</plugins>
</build>
</project>
and my applicationContext.xml:
Copyright (c) 2013 OpenPlans - www.openplans.org. All rights reserved.
This code is licensed under the GPL 2.0 license, available at the root
application directory.
<!DOCTYPE beans PUBLIC "-//SPRING//DTD BEAN//EN" "http://www.springframework.org/dtd/spring-beans.dtd">
<beans xmlns="http://www.springframework.org/schema/beans"
xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd">
<bean id="casbinWmsInterceptor"
class="fresist.geoserver.casbin.CasbinWmsInterceptor">
<constructor-arg ref="wms"/>
<constructor-arg ref="webMapService"/>
</bean>
<!-- This creates a Service descriptor, which allows the org.geoserver.ows.Dispatcher
to locate it. -->
<bean id="casbinWmsInterceptorService-1.0.0" class="org.geoserver.platform.Service">
</bean>
</beans>
Any hints what might be still wrong are greatly appreciated ![]()
Kind regards
Dominik
