Good Afternoon,
I'm trying to get a grid 50km x 50km over a map projection I have.
Using d.grid I go through the steps puuting in the below
d.grid
OPTION: Size of grid to be drawn
key: size
format: value
required: YES
enter option > 50000
You have chosen:
size=50000
Is this correct? (y/n) [y] y
OPTION: Sets the current grid color
key: color
default: gray
required: NO
enter option > red
You have chosen:
color=red
OPTION: Lines of the grid pass through this coordinate
key: origin
format: easting,northing
default: 0,0
required: NO
enter option > -81.19,50.0
You have chosen:
origin=-81.19,50.0
But all I can display is two red lines in the easting,northing position on the
outside of the map frame. I've tried using a smaller resolution e.g 50
but the same display appears.
Once I have this grid I'll need to print it out overlayed on the map of course
can this be done ?
