What is needed is a v.what (to match r.what). r.what is a non-
interactive query on raster files. It accepts coordinate pairs
(ie points) from a file (or stdin) and prints the category values
and labels at the specified locations for raster maps. Someone
should write v.what do mimic the action of r.what, but for vector
files. The interace could be "cloned" from r.what and the
query/reporting "cloned" from d.what.vect. Anyone up to this
programming task? As contributed code it would be of obvious
value.
|I am using the g.region command non-interactively to create new
|regions, I g.region region=new-region to set the new window.
|This is working GREAT! I would also like to generate a report
|of what is in that window, ie. category, area, sites, etc.
|non-interactively.
|The data I am working with is digitized Natural Resource Inventory
|vector data of an area with a possible 3 sites in each area,
|and I have no need to generated a raster file of this dataset.
|I have used the interactive command of v.what.vect and that gives
|me all the information that I need on the screen, I would like
|to:
| goto the area label point (I can get the UTM from the
| dig_att file),
| find out what the GRASS category code is for the area,
| calculate the area in acres, and
| print this information to a file.
|Has anyone any ideas of a non-interactive command resulting in
|the same information of v.what.vect? Any suggestions on how to
|write the shell to accomplish this task?
|I am generating a table that I will pull information from to
|generate the necessary support files to generate a postscript
|output from mapgen.
|Any assistance is greatly appreciated.
| Cynthia R. Brooks FAX (612) 290-3375
| USDA-SCS
| State GIS Specialist
| St. Paul, Minnesota email attmail!mn600g!mngis!crb
| Comm (612) 290-3645 internet mngis!crb@mn600g.attmail.com
Michael
