did anyone had success to run the community module dds-plugin (https://build.geoserver.org/geoserver/2.28.x/community-latest/geoserver-2.28-SNAPSHOT-dds-plugin.zip) with Geoserver 2.28.x?
I tried with 2.28.0 and 2.28.1 and get following error:
Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘PNGMapProducer’ defined in URL [jar:file:/usr/local/tomcat/webapps/geoserver/WEB-INF/lib/gs-wms-2.28.1.jar!/applicationContext.xml]: Bean instantiation via constructor failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [ org.geoserver.wms.map.RenderedImageMapOutputFormat ]: Constructor threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘BilMapResponse’: Lookup method resolution failed; nested exception is java.lang.IllegalStateException: Failed to introspect Class [org.geoserver.wms.worldwind.BilMapResponse] from ClassLoader [ParallelWebappClassLoader
context: geoserver
delegate: false
----------> Parent Classloader:
java.net.URLClassLoader@3d71d552
Caused by: java.lang.ClassNotFoundException: it.geosolutions.imageio.plugins.raw.RawImageWriterSpi
