A delivery problem was encountered with your message:
Error 101: Unknown user at destination host
Recipient address(es) in error:
ACHET.DCRP@mhs.unc.edu
---- Original text of message follows:
YOu should be able to create a postscript file
and just send the file to your printer.
If I recall, it's the following:
p.select
p.map
ppmtops.
--Xin Zhuang
zhuang@access.digex.com
------------------------- Original message header:
From grass-lists-owner@max.cecer.army.mil Thu 27 May 1993 09:26
X-Envelope-To: ACHET.DCRP@mhs.unc.edu
Return-Path: <grass-lists-owner@max.cecer.army.mil>
Received: from mento.oit.unc.edu ([152.2.22.70]) by mhs.unc.edu (SMTPSRV); Thu 27 May 1993 09:26
Received: from max.cecer.army.mil by mento.oit.unc.edu (NeXT-1.0 (From Sendmail 5.52)/TAS/11-16-88)
id AA20678; Thu, 27 May 93 09:31:49 EDT
Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA22742
(5.67a/IDA-1.5 for <ACHET.DCRP@mhs.unc.edu>); Thu, 27 May 1993 08:31:02 -0500
Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA26284; Thu, 27 May 93 08:26:08 CDT
Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id AA15025
(5.67a/IDA-1.4.4 for <grassu-people@amber>); Thu, 27 May 1993 08:26:06 -0500
Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1)
id AA26278; Thu, 27 May 93 08:26:04 CDT
Received: from access.digex.net by max.cecer.army.mil with SMTP id AA22531
(5.67a/IDA-1.5 for <grassu-list@max.cecer.army.mil>); Thu, 27 May 1993 08:26:03 -0500
Received: by access.digex.net id AA13594
(5.65c/IDA-1.4.4 for grassu-list@max.cecer.army.mil); Thu, 27 May 1993 09:26:01 -0400
Date: Thu, 27 May 1993 09:26:01 -0400
Message-Id: <199305271326.AA13594@access.digex.net>
Sender: lists-owner@max.cecer.army.mil
Reply-To: grassu-list@max.cecer.army.mil
Precedence: Bulk
Subject: Re: printing from grass4.0 Help on printing from grass
------------------------- End of message header:
