Ian - we installed grass with the alpha patch 7 - thanks.
However, we are finding it buggy - so far most of the
vector programs don't work. The error messages point
to type conflicts, etc.
I previously successfully installed GRASS using the alpha
patch 4. This was on an older system running OSF/1 v3.2.
I've now upgraded to Digital Unix v4.0. We are wondering
if this is the problem. Have you done a successful install,
and which OS version are you using? Suggestions?
thanks a lot - Simon Cox
__________________________________________________
Dr Simon Cox - Australian Geodynamics Cooperative Research Centre
CSIRO Exploration & Mining, PO Box 437, Nedlands, WA 6009 Australia
T: +61 8 9389 8421 F: +61 8 9389 1906 simon@ned.dem.csiro.au
http://www.ned.dem.csiro.au/CoxSimon/
