Digitizer Question
I've seen this message before, but never got as far as digitizing when this
message occurred because the problem was, the computer wasn't talking to
the digitizer (getting a response). In our case it was a matter of getting
the settings on the digitizer correct (parity, stop/start bits, etc). So maybe
something like this needs to be adjusted.
P.S. you should put your e-mail address in your signature block.
Stuart Bradshaw
lewis!bradshaw@cerl.cecer.army.mil
When we go into v.digit and try to register the map we get the following error messages:
     HOLD: Digitizer is out of sync
            Trying to recover
            Recovered
            Continue
The digitizer seems to accept the points and will allow you to digitize, however
the error messages make this damn near impossible.
_________________________________________________________________
| Scott Walker |
| U.S. Army, Corps of Engineers |
| Fort Worth District |
| CESWF-PL-RE |
| PO Box 17300 |
| Fort Worth, TX 76102-0300 |
| ph (817) 334-3246 |
| fax (817) 885-7539 |
|_______________________________________________________________|
