In article <199503242045.OAA01098@max.cecer.army.mil> you wrote:
: GRASSers,
: I am trying to get a digitizer set up to run on our system with
: GRASS. I have been running into problems and my system adm. asks
: that I find out
: 'What stty or gettydefs peramiters need to be set up for the port
: the digitizer is connected to?'
: My port is /dev/ttyr8 and the current settings as seen by the
: command # stty -a </dev/ttyr8 are:
You can forget gettydefs - it only is read by getty when trying to login a
user. You should make sure that there is no process trying to
run a login - or you won't be able to connect your digitizer.
About the other stuff - it's digitizer dependent. Good luck, make chure you
chmod the port to permission 666!
Robert C. White, Jr. rcw@whitestar.com
The WhiteStar Corp Malamutes!
Digital Cartography Mush and mush and mush and mush and...
Englewood, Colorado Just double click on the snow nose...
