Discourse email formatting test
The body of this email is in text/plain format,
includes consecurive dashes ( ----- ) and 4 backslashes ( \\\\ )
and also uses characters which are forbidden in html like those
used in <tags> and in &entities;
The reason I'm sending it is to verify the email formatting bug
reported in trac [1] is really fixed.
I'm also gpg-signing this email, just in case the gpg signature
stripping bug [2] was also fixed somehow.
I guess my email address will still be lost [3] upon hitting
Discourse topic watchers due to Discourse modifying the mail
but let's keep an eye on that too.
[1] #3073 (Discourse text/plain email use html entities, markdown and backslash-escapes for no reason) – OSGeo
[2] https://trac.osgeo.org/osgeo/ticket/3109
[3] #3072 (Discourse emails do not contain real sender email) – OSGeo
--strk;
  Libre GIS consultant/developer
  strk's services
Sandro Santilli wrote:
--DG962+RbJVV7Aw4t
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
.... but it is still multipart,
  Martin
> --DG962+RbJVV7Aw4t
Which one ? From myself or from Discourse ?
Meanwhile this mail of yours to me from Mailman in great shape but
from Discourse with a very bad look:
https://trac.osgeo.org/osgeo/ticket/3073#comment:15
--strk;
> > --DG962+RbJVV7Aw4t
I don't know if you received my questions, Martin,
I think the mail you referred to was multi-part due
to a GPG signature I've added. I'm not adding one
to this mail, which should then be just text/plain
--strk;
  strk's services
I'm receiving them as text/plain email, and mine should be also text/plain
ciao
Luca
www.lucadelu.org
[ intentionally sent to a single recipient being the SAC mailing list ]
Thanks, I confirm your was received here (via Mailman) as text/plain
as well, and passing DKIM authentication results from my server:
  Authentication-Results: hst.kbt.io;
    dkim=pass (2048-bit key; unprotected)
    header.d=gmail.com
But it seems it failed DMARC on another server due to the envelope-from
being @osgeo.org while the From was @gmail.com:
  Authentication-Results: spool.mail.gandi.net;
     dmarc=fail reason="SPF not aligned (relaxed), No valid DKIM"
     header.from=gmail.com (policy=none);
     smtp.mailfrom="SRS0=oZp/=IY=lists.osgeo.org=sac-bounces@osgeo.org"
     spf=pass (spool.mail.gandi.net: domain of "SRS0=oZp/=IY=lists.osgeo.org=sac-bounces@osgeo.org" designates 140.211.15.3 as permitted sender)
--strk;
  strk's services
