Discussion: Support writing tests with pytest
I will try to keep this thread as the main place for discussing the project.
Just a quick question to start:
I have noticed that most of the gunittest tests seem to depend on the nc_spm_full_v2beta1 dataset. Are any other datasets also used, or is this the only dataset currently used in gunittests?
Also, do we want the pytest command to accept parameters like --location and --grassdata (with defaults), similar to the gunittest command? These may be useful for tester convenience, although they may not be strictly necessary if we create a global fixture to use nc_spm_full dataset.
I’m currently looking into integration of the nc_spm datasets and isolation of the test environment.
cc @wenzeslaus @cwhite911
