Disks specification for osgeo6
Dear Lance
We are planning to finish the mail server movement this weekend, then osgeo6 machine we can:
  • install an additional disks
  • format and install the OS needed for virtualization
We need to buy the additional disks, can you help us with the specifications based on the hardware we have. We at least need 2 for RAID.
Thanks
Vicky from OSGeo SAC
> - install an additional disks
> - format and install the OS needed for virtualization
I need to log into the machine to take a closer look. It doesn't look like our ssh
key or our normal "osuadmin" user is on the system. Can you please add it
and use the following ssh key?
Thanks!
ssh-rsa
AAAAB3NzaC1yc2EAAAADAQABAAACAQDnBjOARXUzKUzYmdYe2UdpUhoZgG
2YeqS2mQF/YgNx7gJJbLn/v8GjV5efDGl0Ad2rW6CO30keN92V6U4oBs2W0+tF
NyFScd8NYLPW+ijz7wtAuE4Vf2yJCXa8zFZzi2nTayIekufYsZvk55GhFUav1NFAh7
EeQjBnFLck7wlnA6ENCYxIHFFtRRTYv3LCHdvfUtWuKbDim1UWxHufQj1q8ay7
32nV6RTzVwH4PDDCJjsgxMDcZqfRcRrQE3n98Bzkb/TAG22G3E2KOa+RTtwxRj
aMs/ZKA9lV3MjeLUk8SQW9h64hiZB1tl5njVfhC6shtdgKZy/JUiV97IF+2NbBC2L
Q/AsGgYUGkPwwR8SiFhzxy5lqrQo9eXVLs6NuM6Q9GdRfOhigxw9ukQPYu29z
4Uq4EaWQgtszXmy5hwkPKA1gIEj6ZpYl2y481wGEdXBoK9m1avs0EVlhQ5pXKv
1XAn2icqGsaiajSyqNeYRH87q25I+VKJcPCSW7uVDWm+sTFUWe++5hAcHym0
QAzmCYwAqYBwdCZl8oepZUA7Szalqxu9Vdka/IjoKiTDJjWf8NWAMs8v6sOvym
dzZD4+I3JFkPOrtG3m+Ex6dRB1BQ63Hzmjx+BuiUU95/YsYq5CwGOjkkr+O29H
wOBnxfnDqakKULh9H/28Zftco2qUphLQ== osuosl unmanaged
Lance Albertson
Director
Oregon State University | Open Source Lab
Account created and member of sudoers and key added. Let us know if you run into issues using it.
> > > then
RAID.
Works!
Looks like this system has 6 slots which are all currently filled with 480G 2.5"
SATA Intel SSD's. So you can't add anymore, but you could replace some. How
would you like to proceed?
Lance Albertson
Director
Oh didn't realize they were SSDs so it's a combo of RAID1 and RAID 5 config I see.
Ideally we'd want to have at least 6 TB of workable disk space. Is it possible to replace some of the disks but not all, or you think it's bad to have a mix of disks.
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 447.1G 0 disk
└─sda1 8:1 0 447.1G 0 part
  └─md1 9:1 0 1.3T 0 raid5
    ├─ogdata-www 253:0 0 75G 0 lvm /var/www
    ├─ogdata-home 253:1 0 50G 0 lvm /home
    ├─ogdata-mailman 253:2 0 60G 0 lvm /var/lib/mailman
    └─ogdata-download 253:3 0 150G 0 lvm /osgeo/download
sdb 8:16 0 447.1G 0 disk
└─sdb1 8:17 0 447.1G 0 part
sdc 8:32 0 447.1G 0 disk
└─sdc1 8:33 0 447.1G 0 part
sdd 8:48 0 447.1G 0 disk
└─sdd1 8:49 0 447.1G 0 part
sde 8:64 0 74.5G 0 disk
└─sde1 8:65 0 74.5G 0 part
  └─md0 9:0 0 74.5G 0 raid1
    ├─osgeo6-boot 253:4 0 244M 0 lvm /boot
    ├─osgeo6-root 253:5 0 18.6G 0 lvm /
    ├─osgeo6-swap 253:6 0 14.9G 0 lvm [SWAP]
    └─osgeo6-var 253:7 0 18.6G 0 lvm /var
sdf 8:80 0 74.5G 0 disk
└─sdf1 8:81 0 74.5G 0 part
> > > then
RAID.
Works!
Lance Albertson
Director
Thanks!
ssh-rsa
Lance Albertson
Director
Works!
2.5" SATA Intel SSD's. So you can't add anymore, but you could replace some. How
Lance Albertson
Director
[Moved this to our ticketing system]
On Fri Sep 19 10:05:58 2025, lance@osuosl.org wrote:
---------- Forwarded message ---------
Date: Fri, Sep 19, 2025 at 9:11 AM
Subject: Disks specification for osgeo6
To: lance@osuosl.org <lance@osuosl.org>
Cc: System Administration Committee Discussion/OSGeo <sac@lists.osgeo.org>
Dear Lance
machine we can:
ssh key or our normal "osuadmin" user is on the system. Can you please add it
Thanks!
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAACAQDnBjOARXUzKUzYmdYe2UdpUhoZgG2YeqS2mQF/YgNx7gJJbLn/v8GjV5efDGl0Ad2rW6CO30keN92V6U4oBs2W0+tFNyFScd8NYLPW+ijz7wtAuE4Vf2yJCXa8zFZzi2nTayIekufYsZvk55GhFUav1NFAh7EeQjBnFLck7wlnA6ENCYxIHFFtRRTYv3LCHdvfUtWuKbDim1UWxHufQj1q8ay732nV6RTzVwH4PDDCJjsgxMDcZqfRcRrQE3n98Bzkb/TAG22G3E2KOa+RTtwxRjaMs/ZKA9lV3MjeLUk8SQW9h64hiZB1tl5njVfhC6shtdgKZy/JUiV97IF+2NbBC2LQ/AsGgYUGkPwwR8SiFhzxy5lqrQo9eXVLs6NuM6Q9GdRfOhigxw9ukQPYu29z4Uq4EaWQgtszXmy5hwkPKA1gIEj6ZpYl2y481wGEdXBoK9m1avs0EVlhQ5pXKv1XAn2icqGsaiajSyqNeYRH87q25I+VKJcPCSW7uVDWm+sTFUWe++5hAcHym0QAzmCYwAqYBwdCZl8oepZUA7Szalqxu9Vdka/IjoKiTDJjWf8NWAMs8v6sOvymdzZD4+I3JFkPOrtG3m+Ex6dRB1BQ63Hzmjx+BuiUU95/YsYq5CwGOjkkr+O29HwOBnxfnDqakKULh9H/28Zftco2qUphLQ== osuosl unmanaged
Lance Albertson
Director
> How would you like to proceed?
see. Ideally we'd want to have at least 6 TB of workable disk space. Is it
So currently this is how the RAID is split:
md0 : active raid1 sdf1[1] sde1[0]
      78084096 blocks super 1.2 [2/2] [UU]
md1 : active raid5 sda1[0] sdd1[3] sdc1[2] sdb1[1]
      1406155776 blocks super 1.2 level 5, 512k chunk, algorithm 2 [4/4] [UUUU]
      bitmap: 0/4 pages [0KB], 65536KB chunk
PV VG Fmt Attr PSize PFree
/dev/md0 osgeo6 lvm2 a-- 74.46g <22.08g
/dev/md1 ogdata lvm2 a-- <1.31t 1006.01g
LV VG Attr LSize
download ogdata -wi-ao---- 150.00g
home ogdata -wi-ao---- 50.00g
mailman ogdata -wi-ao---- 60.00g
www ogdata -wi-ao---- 75.00g
boot osgeo6 -wi-ao---- 244.00m
root osgeo6 -wi-ao---- 18.62g
swap osgeo6 -wi-ao---- <14.90g
var osgeo6 -wi-ao---- 18.62g
Which volume(s) do you want to increase the capacity on? I'm assuming it's
anything on the "ogdata" volume group which is the RAID5.
We could expand the space of that online, however it would require replacing all
four disks with the same size disk. We would have to replace them one by one
allowing the RAID to rebuild. The last replacement should allow us to expand the
pv and vg.
Does this help?
Lance Albertson
Director
[UUUU]
LV VG Attr LSize
all four disks with the same size disk. We would have to replace them one by
one allowing the RAID to rebuild. The last replacement should allow us to
expand the pv and vg.
Does this help?
Lance Albertson
Director
We want the whole server reformatted so what is currently there is irrelevant.
No need to try to salvage any data.
We switched over mail and lists on that server already to osgeo9 over the weekend.
We plan to keep osgeo6 live for perhaps another week or so and then have you shut it off.
We have a backup of all the pieces we cared to keep already.
Right now we are just trying to figure out how much we want to spend for disks on this server
Vs. how much space we'll be able to expand.
weekend. We plan to keep osgeo6 live for perhaps another week or so and then
on this server Vs. how much space we'll be able to expand.
Well that makes it easy :slight_smile:
The only requirements you need is that the disks need to be SATA and 2.5" form
factor. Other than that, anything should work.
Lance Albertson
Director
[UUUU]
LV VG Attr LSize
Does this help?
Lance Albertson
Director
Hi all
This the option Regina found:
https://www.amazon.com/SAMSUNG-Inch-Internal-MZ-77E1T0B-
AM/dp/B08QB93S6R/ref=sr_1_1?crid=2GY3TIQOCCXY4&th=1
We would use size 2TB disks: $186 * 6 = $1116 Will give us 12TB space which
I think will be at least 6TB of usable space (RAID would take the other 6TB)
Keep in mind we are throwing out osgeo3 and osgeo4 (which has all the
backups, staging) So we do need the space
Please let me know your comments
Regards
Vicky
My only concern is what Grant mentioned
that these disks are really not meant for server use and that we should look for Pro or Data
Center editions disks from resellers.
I'm not sure of reliable resellers though and an unreliable one is probably worse than getting not optimal disks.
Grant,
You have any thoughts on good resellers. I don't think we want to spend more than $2000 on these disks
Given we might not have use for this server after a year or so.
Regina
Are our current drives enterprise models?
OSGeo6 new SSD disks for SAC
On Thu Oct 23 13:07:57 2025, vicky@erosion.dev wrote:
Hi all
Amazon.com
Will give us 12TB space which I think will be at least 6TB of usable space
Keep in mind we are throwing out osgeo3 and osgeo4 (which has all the backups,
Looks good from my point of view.
Lance Albertson
Director
Hi all
Regards
Vicky
On Mon, Sep 22, 2025 at 9:02 AM Lance Albertson via RT <support@osuosl.org>
irrelevant.
then
disks
form
Lance Albertson
Director
Hi all
https://www.amazon.com/SAMSUNG-Inch-Internal-MZ-77E1T0B-AM/dp/B08QB93S6R/ref=sr_1_1?crid=2GY3TIQOCCXY4&th=1
Will give us 12TB space which I think will be at least 6TB of usable space (RAID would take the other 6TB)
Keep in mind we are throwing out osgeo3 and osgeo4 (which has all the backups, staging) So we do need the space
Regards
Vicky
On Mon, Sep 22, 2025 at 9:02 AM Lance Albertson via RT <support@osuosl.org> wrote:
on this server Vs. how much space we’ll be able to expand.
Lance Albertson
Director
On Thu, 23 Oct 2025 at 23:31, Regina Obe <lr@pcorp.us> wrote:
Grant,
Do you NEED SATA or SAS?
There are quite a few Samsung 860 Pro SATA disks available on ebay.
I've bought from this reseller in the past and they seem reputable:
The remaining endurance / write capacity is important, unfortunately
not stated by listing.
Firmware easily available, but may need to flashed from ISO when
connected to SATA controller (not hardware RAID)
They also have larger Samsung disks, but no direct experience with this model:
Firmware is harder to find, but few forums have links.
Kind regards,
Grant
