Dear All,
I have a lizmap project that seems well configured.
I have a point layer stored on Postgres. WFS is enabled and I can see the edit button:
But when I click on it I have this error :
Edit layer : can’t access to the edit form
I’m not able to figure out what is the problem
QGIS Server: [3.34.9 ]
Lizmap: 3.8.4
Thanks
Pierluigi
Do you have any logs in errors.log or lizmap-admin.log ?
Thanks for the tips…
Looking at the logs it was clear that the library php+postgres was not installed.
Now it works.
Could be better to write in documentation to add this package in case of layer edit?
Thanks again
gustry
4
Yes of course if it’s needed.
Which file or URL did you look at ?
You can edit a file straight on GitHub web interface to make your proposal.
gustry
5
These logs are displayed in your administration panel, you should go there from time to time
