Elf & COFF
Vitaly,
SGI changed their object file format when they went to IRIX 5._
So in order to compile a new grass program (which uses previously
compiled libraries), you will have to recompile the libraries. You
should probably delete all the object & executables in GRASS and
recompile the whole thing. If you have some systems which are still
using IRIX 4._ sharing the same executables, then just recompile
GRASS under 5.2 with a different head file containing different
ARCH and GISBASE (see the head file I sent you for a few other flag
settings that are different under 5.2). Then on any systems that
run 5.2, the grass4.1 & xgrass4.1 startup scripts need to reflect
the different GISBASE.
- Bill Brown
PS - your "who" & "directory" requests should be sent to:
     grassp-request@max.cecer.army.mil
     (not grassp-list@max.cecer.army.mil)
