Errors r.terraflow
Hello everybody! I just started using QGIS for university and I’m trying to extract a river network through the flow accumulation of a catchment. r.terraflow produces this error, can anybody help me? Thank you very much!!
QGIS version: 3.38.3-Grenoble
QGIS code revision: 37f9e6efee
Qt version: 5.15.13
Python version: 3.12.6
GDAL version: 3.9.2
GEOS version: 3.12.2-CAPI-1.18.2
PROJ version: Rel. 9.4.0, March 1st, 2024
PDAL version: 2.6.3 (git-version: b5523a)
GRASS version: 8.4.0
Algorithm started at: 2025-03-26T11:18:17
Algorithm ‘r.terraflow’ starting…
Input parameters:
{ ‘-s’ : True, ‘GRASS_RASTER_FORMAT_META’ : ‘’, ‘GRASS_RASTER_FORMAT_OPT’ : ‘’, ‘GRASS_REGION_CELLSIZE_PARAMETER’ : 0, ‘GRASS_REGION_PARAMETER’ : None, ‘accumulation’ : ‘TEMPORARY_OUTPUT’, ‘d8cut’ : None, ‘direction’ : ‘TEMPORARY_OUTPUT’, ‘elevation’ : ‘C:/Users/carlo/OneDrive - ETH Zurich/Documenti/Assistenz/Watershed modelling/Kleine Emme/Elev.asc’, ‘filled’ : ‘TEMPORARY_OUTPUT’, ‘memory’ : 300, ‘stats’ : ‘TEMPORARY_OUTPUT’, ‘swatershed’ : ‘TEMPORARY_OUTPUT’, ‘tci’ : ‘TEMPORARY_OUTPUT’ }
g.proj -c wkt=“C:/Users/carlo/AppData/Local/Temp/processing_xQKbvb/583b2723692a44bcafe5143912e747b1/crs.prj”
r.in.gdal input=“C:\Users\carlo\OneDrive - ETH Zurich\Documenti\Assistenz\Watershed modelling\Kleine Emme\Elev.asc” band=1 output=“rast_67e3d469a49543” --overwrite -o
g.region n=218087.5 s=169987.5 e=672587.5 w=619987.5 res=100.0
r.terraflow elevation=rast_67e3d469a49543 -s memory=300 filled=filled2b45a33d15084a7db28305726ed0485d direction=direction2b45a33d15084a7db28305726ed0485d swatershed=swatershed2b45a33d15084a7db28305726ed0485d accumulation=accumulation2b45a33d15084a7db28305726ed0485d tci=tci2b45a33d15084a7db28305726ed0485d stats=“C:/Users/carlo/AppData/Local/Temp/processing_xQKbvb/e96539c438634e03a8046b3cd2fe83e8/stats.txt” --overwrite
g.region raster=filled2b45a33d15084a7db28305726ed0485d
r.out.gdal -t -m input=“filled2b45a33d15084a7db28305726ed0485d” output=“C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\909082c89bcb46eeae1192a4a6f6d271\filled.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
g.region raster=direction2b45a33d15084a7db28305726ed0485d
r.out.gdal -t -m input=“direction2b45a33d15084a7db28305726ed0485d” output=“C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\e8de7bee922e425b828981d9da804b6e\direction.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
g.region raster=swatershed2b45a33d15084a7db28305726ed0485d
r.out.gdal -t -m input=“swatershed2b45a33d15084a7db28305726ed0485d” output=“C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\768c864f36fe44b3b0f829bf812789d4\swatershed.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
g.region raster=accumulation2b45a33d15084a7db28305726ed0485d
r.out.gdal -t -m input=“accumulation2b45a33d15084a7db28305726ed0485d” output=“C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\ea0f118704184accbe86b59762ffe877\accumulation.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
g.region raster=tci2b45a33d15084a7db28305726ed0485d
r.out.gdal -t -m input=“tci2b45a33d15084a7db28305726ed0485d” output=“C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\a2e1939662d34f5c9a587bbc8da7b2ef\tci.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
WARNING: Concurrent mapset locking is not supported on Windows
C:\Users\carlo\Documents>chcp 1252 1>NUL
C:\Users\carlo\Documents>g.proj -c wkt=“C:/Users/carlo/AppData/Local/Temp/processing_xQKbvb/583b2723692a44bcafe5143912e747b1/crs.prj”
Default region was updated to the new projection, but if you have multiple mapsets g.region -d should be run in each to update the region from the default
Projection information updated
C:\Users\carlo\Documents>r.in.gdal input=“C:\Users\carlo\OneDrive - ETH Zurich\Documenti\Assistenz\Watershed modelling\Kleine Emme\Elev.asc” band=1 output=“rast_67e3d469a49543” --overwrite -o
No projection information available
Over-riding projection check
Importing raster map <rast_67e3d469a49543>…
0..3..6..9..12..15..18..21..24..27..30..33..36..39..42..45..48..51..54..57..60..63..66..69..72..75..78..81..84..87..90..93..96..99..100
C:\Users\carlo\Documents>g.region n=218087.5 s=169987.5 e=672587.5 w=619987.5 res=100.0
C:\Users\carlo\Documents>r.terraflow elevation=rast_67e3d469a49543 -s memory=300 filled=filled2b45a33d15084a7db28305726ed0485d direction=direction2b45a33d15084a7db28305726ed0485d swatershed=swatershed2b45a33d15084a7db28305726ed0485d accumulation=accumulation2b45a33d15084a7db28305726ed0485d tci=tci2b45a33d15084a7db28305726ed0485d stats=“C:/Users/carlo/AppData/Local/Temp/processing_xQKbvb/e96539c438634e03a8046b3cd2fe83e8/stats.txt” --overwrite
SFD (D8) flow direction
D8CUT=999999986991104.000000
Memory size: 300.00M (314572800) bytes
COMPUTING FLOW DIRECTIONS
classifying nodata (inner & boundary)
assigning preliminary directions
finding flat areas (plateaus and depressions)
assigning directions on plateaus
generating watersheds and watershed graph
flooding depressions
REASSIGNING DIRECTIONS
creating flowStream: [AMI_STREAM C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\grassdata\temp_location\PERMANENT.tmp/unknown\19856.0/flowStream 0]
compute flow directions done.
WARNING: Raster map <rast_67e3d469a49543> is of type CELL_TYPE – you should use r.terraflow.short
Reading input data…
WARNING: Watershed 1 (R=1) not done
Writing to raster map …
ERROR: Rast_make_random_colors: min (1) > max (0)
C:\Users\carlo\Documents>g.region raster=filled2b45a33d15084a7db28305726ed0485d
C:\Users\carlo\Documents>r.out.gdal -t -m input=“filled2b45a33d15084a7db28305726ed0485d” output=“C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\909082c89bcb46eeae1192a4a6f6d271\filled.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
ERROR 6: filled.tif, band 1: SetColorTable() only supported for Byte or UInt16 bands in TIFF format.
Checking GDAL data type and nodata value…
2..5..8..11..14..17..20..23..26..29..32..35..38..41..44..47..50..53..56..59..62..65..68..71..74..77..80..83..86..89..92..95..98..100
Using GDAL data type
Exporting raster data to GTiff format…
r.out.gdal complete. File <C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\909082c89bcb46eeae1192a4a6f6d271\filled.tif> created.
C:\Users\carlo\Documents>g.region raster=direction2b45a33d15084a7db28305726ed0485d
C:\Users\carlo\Documents>r.out.gdal -t -m input=“direction2b45a33d15084a7db28305726ed0485d” output=“C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\e8de7bee922e425b828981d9da804b6e\direction.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
r.out.gdal complete. File <C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\e8de7bee922e425b828981d9da804b6e\direction.tif> created.
C:\Users\carlo\Documents>g.region raster=swatershed2b45a33d15084a7db28305726ed0485d
C:\Users\carlo\Documents>r.out.gdal -t -m input=“swatershed2b45a33d15084a7db28305726ed0485d” output=“C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\768c864f36fe44b3b0f829bf812789d4\swatershed.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
r.out.gdal complete. File <C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\768c864f36fe44b3b0f829bf812789d4\swatershed.tif> created.
C:\Users\carlo\Documents>g.region raster=accumulation2b45a33d15084a7db28305726ed0485d
ERROR: Raster map not found
C:\Users\carlo\Documents>r.out.gdal -t -m input=“accumulation2b45a33d15084a7db28305726ed0485d” output=“C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\ea0f118704184accbe86b59762ffe877\accumulation.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
ERROR: Raster map or group not found
C:\Users\carlo\Documents>g.region raster=tci2b45a33d15084a7db28305726ed0485d
C:\Users\carlo\Documents>r.out.gdal -t -m input=“tci2b45a33d15084a7db28305726ed0485d” output=“C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\a2e1939662d34f5c9a587bbc8da7b2ef\tci.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
C:\Users\carlo\Documents>exit
Premere un tasto per continuare . . .
Execution completed in 6.92 seconds
Results:
filled: C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\909082c89bcb46eeae1192a4a6f6d271\filled.tif
direction: C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\e8de7bee922e425b828981d9da804b6e\direction.tif
swatershed: C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\768c864f36fe44b3b0f829bf812789d4\swatershed.tif
accumulation: C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\ea0f118704184accbe86b59762ffe877\accumulation.tif
tci: C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\a2e1939662d34f5c9a587bbc8da7b2ef\tci.tif
stats: C:\Users\carlo\AppData\Local\Temp\processing_xQKbvb\e96539c438634e03a8046b3cd2fe83e8\stats.txt
Loading resulting layers
The following layers were not correctly generated.
• C:/Users/carlo/AppData/Local/Temp/processing_xQKbvb/ea0f118704184accbe86b59762ffe877/accumulation.tif
You can check the ‘Log Messages Panel’ in QGIS main window to find more information about the execution of the algorithm.
Looks like something is wrong with the sink-watershed raster, if you don’t compute it, does it still fail? It’s hard to debug this without reproducible example.
Thank you!! This is the catchment: polybox . I tried without the sink-watershed and I get a slightly different output: COMPUTING FLOW DIRECTIONS
creating flowStream: [AMI_STREAM C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\grassdata\temp_location\PERMANENT.tmp/unknown\25612.0/flowStream 0]
Reading input data…
0…3…6…9…12…15…18…21…24…27…30…33…36…39…42…45…48…51…54…57…60…63…66…69…72…75…78…81…84…87…90…93…96…99…100
C:\Users\carlo\Documents>g.region raster=filled249551de998e4268b59d2f81133eed21
C:\Users\carlo\Documents>r.out.gdal -t -m input=“filled249551de998e4268b59d2f81133eed21” output=“C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\bb5feec0309442deab430a13a8c148a3\filled.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
2…5…8…11…14…17…20…23…26…29…32…35…38…41…44…47…50…53…56…59…62…65…68…71…74…77…80…83…86…89…92…95…98…100
r.out.gdal complete. File <C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\bb5feec0309442deab430a13a8c148a3\filled.tif> created.
C:\Users\carlo\Documents>g.region raster=direction249551de998e4268b59d2f81133eed21
C:\Users\carlo\Documents>r.out.gdal -t -m input=“direction249551de998e4268b59d2f81133eed21” output=“C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\531dbc7ae4194c059ad048975c5629d3\direction.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
r.out.gdal complete. File <C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\531dbc7ae4194c059ad048975c5629d3\direction.tif> created.
C:\Users\carlo\Documents>g.region raster=swatershed249551de998e4268b59d2f81133eed21
C:\Users\carlo\Documents>r.out.gdal -t -m input=“swatershed249551de998e4268b59d2f81133eed21” output=“C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\9a5298fa0ab24230b949544fa8e8af11\swatershed.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
r.out.gdal complete. File <C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\9a5298fa0ab24230b949544fa8e8af11\swatershed.tif> created.
C:\Users\carlo\Documents>g.region raster=accumulation249551de998e4268b59d2f81133eed21
C:\Users\carlo\Documents>r.out.gdal -t -m input=“accumulation249551de998e4268b59d2f81133eed21” output=“C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\a33f0decfa9f42b09edf96e3d4b9a5d6\accumulation.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
C:\Users\carlo\Documents>g.region raster=tci249551de998e4268b59d2f81133eed21
C:\Users\carlo\Documents>r.out.gdal -t -m input=“tci249551de998e4268b59d2f81133eed21” output=“C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\81ff75869f134897aba56010c0b795f2\tci.tif” format=“GTiff” createopt=“TFW=YES,COMPRESS=LZW” --overwrite
Execution completed in 7.59 seconds
Results:
filled: C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\bb5feec0309442deab430a13a8c148a3\filled.tif
direction: C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\531dbc7ae4194c059ad048975c5629d3\direction.tif
swatershed: C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\9a5298fa0ab24230b949544fa8e8af11\swatershed.tif
accumulation: C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\a33f0decfa9f42b09edf96e3d4b9a5d6\accumulation.tif
tci: C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\81ff75869f134897aba56010c0b795f2\tci.tif
stats: [C:\Users\carlo\AppData\Local\Temp\processing_AGcHTO\5d06f94bf5c24336ae82f7dfa1e6e6b5\stats.txt](file:///C:/Users/carlo/AppData/Local/Temp/processing_AGcHTO/5d06f94bf5c24336ae82f7dfa1e6e6b5/stats.txt)
• C:/Users/carlo/AppData/Local/Temp/processing_AGcHTO/a33f0decfa9f42b09edf96e3d4b9a5d6/accumulation.tif
It looks like it is still computing it. When I try locally and omit that output, it works. But it looks like there is some problem with that specific output.
So when you omit the sink-watershed you get the accumulation raster? How do you omit it then? Because on mine it doesn’t show…
That’s a QGIS question, if you run it directly from GRASS it works fine.
Alternatively, have you tried r.watershed?
