Excel WFS extension profile missing >= 2.27.3
Geoserver 2.27.3 (and newer versions) does not define a profile for Excel WFS extension. Due to the missing profile definition, no Excel-related (WFS) jar files are being included into a compiled Geoserver WAR file, thus Excel WFS download options (Excel & Excel 2007) are not available on the Layer preview web page.
I bisected the issue. The change happened at the following commit:
Earlier, including “excel” extension for Maven compilation process worked flawlessly. But that is not the case any more.
The fix is quite trivial: simply adding the missing Excel WFS profile into src/web/app/pom.xml, and compiling Geoserver WAR with the added profile (excel-wfs in my case).
  • Without the patch and extension xlsxppio defined for Maven, only gs-excel-wps-<version>.jar and gs-excel-core-<version>.jar are bundled into the WAR.
  • With the patch, and excel-wfs extension defined for Maven, gs-excel-wfs-<version>.jar is also bundled, and Excel WFS download options are working correctly in Layer preview web page drop-down download menus.
I have provided the patch file here:
(you may apply contents of the patch to the upstream Geoserver code as you wish)
I would have had opened a new issue to the Geoserver issue tracker but I don’t have necessary permissions to do so.
Thank you. I hope this helps you fixing the issue! :slight_smile:
May I suggest opening a PR with your patch? That way we can at least get it into the mix.
I have lost track of what the issue is with Jira, sometimes we have exhausted the number of users available to us without paying. I would like to see the project change over to github issues.
I have created the Jira issue for you: Jira
Can you tackle the rest, please @Fincer ?
Peter
Thanks for opening the Jira issue! Unfortunately, my Jira account does not have sufficient permissions to add the patch file. I think it would be the easiest route if someone with proper rights could add the patch code (after proper testing, of course).
Personally, I have used the patch in 2.27.3 to 2.28.2 with success.
Raw patch code is available at: https://fjordtek.com/git/Fincer/geoserver_excel_patch/raw/branch/main/01_excel-wfs.patch
It really needs to be a PR against main on github
Ian
Hi @Fincer , here is the way to get your patch into the source code: Pull Requests - Documentation
The problems with Jira should not stop you from doing the above, and you can link the Jira issue I created.
Peter
PR: [GEOS-12125] Add missing excel-wfs profile to web app WAR build by petersmythe · Pull Request #9582 · geoserver/geoserver · GitHub
