At 12:04 AM 11/7/96 GMT, you wrote:
Grass users-----
I need to export a (large) grass raster map into some kind
of format that is readable by IDRISI, which is, I'm told
accomplished with a "fixed length 1024 byte format ASCII
character file." Any suggestions as to the best/easiest
way to do this?Thanks,
Bob Harrington
bobh@hwr.arizona.edu
If the grass raster map is a single-byte type( 0-255 categories), run
r.compress to uncompress the map. The cell file can then be read directly as
an IDRISI image file after the document file is created.
There is also a Grass-IDRISI module that I obtained from the IDRISI folks
and have used successfully.
Jim Schmidt
avenues@sonnet.com
Jim
