Hi
On Fri, 9 Sep 1994 aprc@mail.nerc-bas.ac.uk wrote:> I have found it impossible to ftp from moon.cecer.army.mil from PCs, although
> there is no problem from Workstations. My local support people conjecture that
> this is because our PCs are not DNS registered, while the workstations are. This
> means that if moon.cecer.army.mil attempts to check on the existence of the PC
> systems, it can't find them in the DNS system, and refuses to connect to them,
> for security reasons.
> Can someone confirm or deny this hypothesis?Well it depends what the real problem is. You don' get connected or is he
denying your access eventhough the port is opened. I he refuses indeed to
open the port that is indeed the reason. Can you make with your pc a
telnet session on an external workstation outside your local network
If not I confirm your problem and than you have to ftp over
the workstations if they are connected with the pc. Inform me about it,
maybe you can save by this needless searching!Bart
Ir. Bart Cosyn
Laboratory of Hydrology & Watermanagement
Fac. of Agricultural Sciences and Applied Biological Sciences
University of Gent
Coupure Links 653
B-9000 Gent
Belgium
Tel +/32/9/264/61/37
Fax +/32/9/264/62/36
E_mail:Bart.Cosyn@rug.ac.be | or bcosyn@allserv.rug.ac.be
Hello,
I can ftp to moon.cecer.army.mil from my pc. It is a gateway 2000 486.
I'm at Michigan State University, I'm on ethernet and I'm running PCTCP
by FTP Inc.
Hope this info helps you locate your problem.
Brian Buckley
buckley@ig0.rs.msu.edu
P.S. I don't believe that the dns on campus has this pc listed on it.
