Hi Justin,Gabriel,
Thanks for digging into this. I am looking forward to having SVG as
a format option. If the outputstream approach works can it also be a format
option on WFS as well as WMS?
Thanks
Randy
-----Original Message-----
[mailto:geoserver-devel-admin@lists.sourceforge.net] On Behalf Of Gabriel
Roldán
Sent: Tuesday, October 18, 2005 10:11 AM
To: Justin Deoliveira
Cc: Geoserver-devel
Subject: [Geoserver-devel] Re: SVG Rendering
Hi Justin,
looks good.
I don't remember what the cause was for the memory leak problem involving
clearLayerList(), though I'm aware the problem existed and that was the
solution.
By the way, I was investigating a way of streaming Batik, and looks like we
could be able to get an in-the-middle solution. I mean, writing a subclass
of
Batik's AbstractGraphics2D that instead of making a DOM grow up
indefinitelly
just writes up xml to an outputstream in an element by element basis.
So my plan is first getting that working, then minimizing the verbosity of
generated svg by replacing by-element styling with CSS and class=
attributes.
This would give us a much more memory friendly svg producer with full
styling,
though I don't think I'll have time to dig into it until weekend.
cheers,
Gabriel.
On Tuesday 18 October 2005 07:11, Justin Deoliveira wrote:
Hi Gabriel,
I have been looking at geoserver's svg rendering as per
http://jira.codehaus.org/browse/GEOS-400I tracked the problem down to GetMapResponse. There are two methods of
interest:execute(Request), and writeTo(Request).
The GetMapResponse releases resources of the MapContext
(MapContext#clearLayerList()) at the end of the execute() method, which
means that when the SVGMapProducer doesn't have any layers to render in
the writeTo() method.I changed it so that the resources arent released until the end of the
writeTo() method, which is the end of the requests life cycle.The change is pretty simple but i thought I would run it by you first
since the devil is often in the details.On another note, I created another GetMapProducer that produces svg
using batik instead of the render that you wrote. The bad news is it is
slow (no suprise), however it does all the styling.So we have a couple of options:
1. Only use one of working renders, or
2. Use both, and make it part of the WMS configuration which one to use.Any thoughts?
This SF.Net email is sponsored by:
Power Architecture Resource Center: Free content, downloads, discussions,
and more. http://solutions.newsforge.com/ibmarch.tmpl
Geoserver-devel mailing list
