GDAL-GRASS driver 2.0.0 release candidate released
The GDAL-GRASS driver 2.0.0rc1 release provides more than 15 improvements
and fixes with respect to the release 1.0.4.
Notable changes include added support for GDAL 3.12 and removed support
for Autotools build system.
Special note for packagers: the bump of GDAL-GRASS to version 2.x
introduces the potential of version conflicts from the era when the
driver was part of GDAL core. Please take appropriate action to prevent
that from happening.
What’s Changed
Libraries and General Functionality
  • Adapt GetGeoTransform() method for GDAL 3.12 change, and avoid use of
    deprecated GDALGetDataTypeSize() functions (#67) by @rouault
  • Fix const correctness of virtual methods for GDAL 3.12 (#70) by @rouault
  • C++: modernize code (#37) by @nilason
Documentation and Messages
  • docs: Add license file and use SPDX identifiers (#55) by @nilason
Packaging, Configuration, Portability, and Compilation
  • cmake: replace deprecated ‘exec_program’ (#73) by @nilason
  • config: remove autoconf support (#56) by @nilason
Continuous Integration, Tests, Code Quality, and Checks
  • checks: add pre-commit configuration file (#58) by @nilason
Other Changes
  • Move source files to ‘source’ directory (#60) by @nilason
  • style: fix issues reported by pre-commit (#59) by @nilason
Full Changelog: Comparing 1.0.4...2.0.0rc1 · OSGeo/gdal-grass · GitHub
The release can be downloaded from:
https://download.osgeo.org/gdal-grass/gdal-grass-2.0.0rc1.tar.gz
https://download.osgeo.org/gdal-grass/gdal-grass-2.0.0rc1.tar.gz.md5
https://download.osgeo.org/gdal-grass/gdal-grass-2.0.0rc1.tar.gz.sha256
At some point, there will be a switch from location to project AFAIR. Anything needed for this?
Kind regards
Helli
That name change has not (yet) caused API changes that will break this, so that will probably not be any problem. Future changes with FHS compliance, however, will. But that is a problem further down the road.
