Geo Server Logon page loading with error as "An error occurred while loading the page Oops, something went wrong..."
We have upgraded to 2.27.2 version.
Logon page is displaying with error message as
  • An error occurred while loading the page
Oops, something went wrong…
Sorry, something unexpected happened on the server.
The GeoServer user forum might help you address this issue. Click here to subscribe, and then include in your message the GeoServer version, the complete stack trace below (not a screen snap, include to the end) and the steps to reproduce the problem.
I have attached log.
Please advise how to fix this issue?
Satish
Error Logs
14 Nov 16:31:50 INFO [geoserver.wms] -
Request: getServiceInfo
Request: getMap
Angle = 0.0
BaseUrl = https://server1.abc.buss:8443/geoserver/
Bbox = SRSEnvelope[107.033203125 : 174.568359375, -47.302734375 : -6.662109375]
BgColor = java.awt.Color[r=255,g=255,b=255]
Buffer = 0
Clip = null
CQLFilter = null
Crs = GEOGCS[“GDA2020”,
DATUM[“Geocentric Datum of Australia 2020”,
SPHEROID[“GRS 1980”, 6378137.0, 298.257222101, AUTHORITY[“EPSG”,“7019”]],
TOWGS84[0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0],
AUTHORITY[“EPSG”,“1168”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic longitude”, EAST],
AXIS[“Geodetic latitude”, NORTH],
AUTHORITY[“EPSG”,“7844”]]
Elevation =
Env = {}
Exceptions = application/vnd.ogc.se_inimage
FeatureId = null
FeatureVersion = null
Filter = null
Format = image/png
FormatOptions = {}
Get = true
Height = 463
Interpolations =
Layers = [org.geoserver.wms.MapLayerInfo@e2ab0a41]
MaxFeatures = null
Palette = null
RawKvp = {EXCEPTIONS=application/vnd.ogc.se_inimage, REQUEST=GetMap, FORMAT=image/png, SRS=EPSG:7844, BBOX=107.033203125,-47.302734375,174.568359375,-6.662109375, VERSION=1.1.1, STYLES=, SERVICE=WMS, WIDTH=769, HEIGHT=463, TRANSPARENT=true, LAYERS=HEADSUPP:AGPT_ACTIVE_2024_25_FY_ACRRM}
RemoteOwsType = null
RemoteOwsURL = null
Request = GetMap
RequestCharset = UTF-8
ScaleMethod = null
Sld = null
SldBody = null
SldVersion = null
SortBy = null
SortByArrays = null
SRS = EPSG:7844
StartIndex = null
StyleBody = null
StyleFormat = sld
Styles = [StyleImpl[ name=HEADSUPP:Active AGPT Facilities ACRRM]]
StyleUrl = null
StyleVersion = null
Tiled = false
TilesOrigin = null
Time =
Transparent = true
ValidateSchema = false
Version = 1.1.1
ViewParams = null
Width = 769
14 Nov 16:53:26 INFO [geoserver.web] - Failure during page processing
org.apache.wicket.WicketRuntimeException: Error attaching this container for rendering: [OddEvenItem [Component id = 1]]
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1771)
at org.apache.wicket.Component.onBeforeRender(Component.java:3834)
at org.apache.wicket.Component.beforeRender(Component.java:949)
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1759)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:143)
at org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:113)
at org.apache.wicket.Page.onBeforeRender(Page.java:789)
at org.apache.wicket.Page.renderPage(Page.java:991)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:202)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:910)
at org.apache.wicket.request.RequestHandlerExecutor.execute(RequestHandlerExecutor.java:63)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:294)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:255)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:277)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:208)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:529)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:623)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:166)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:51)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1072)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:965)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:154)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:179)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
at org.geoserver.ows.HTTPHeadersCollector.doFilter(HTTPHeadersCollector.java:48)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:67)
at org.geoserver.filters.HTTPMethodFilter.doFilter(HTTPMethodFilter.java:36)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:181)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:39)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:352)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
at org.springframework.security.web.access.intercept.AuthorizationFilter.doFilter(AuthorizationFilter.java:100)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:89)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:361)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:126)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:120)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:52)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:227)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:221)
at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:117)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:110)
at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:101)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilterInternal(GeoServerSecurityContextPersistenceFilter.java:66)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:117)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:225)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:190)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:139)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:354)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:267)
at org.geoserver.filters.SecurityHeadersFilter.doFilter(SecurityHeadersFilter.java:116)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:168)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:90)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:481)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:130)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:93)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:670)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:346)
at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:390)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:63)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:928)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1786)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:52)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:63)
at java.base/java.lang.Thread.run(Thread.java:840)
Caused by: java.lang.IllegalStateException: Could not locate a layer or layer group with id LayerInfoImpl–575839bc:18779a938f3:-7f71 within GeoServer configuration, the GWC configuration seems to be out of synch
Hello!
Could please you share with us the previous version of your GeoServer instance? It would be great also to know how you deploy GeoServer (war file, stand alone install, docker image) and the OS you are deploying on!
Regards
Alexandre
Hello @Satish this is one of my most frustrating problems to encounter, and it used to happen more often before @groldan did some work to make catalog changes more robust.
What happens is, perhaps when moving a layer, the geowebcache tileset is still present. So when GeoWebCache TileSet goes to find the Layer that is making the content - the connection cannot be made.
So specifically you need to search GEOSERVER_DATA_DIR location, the folder gwc-layers will contain a bunch of the xml files (one for each TileSet).
Go through these files and locate the one that contains LayerInfoImpl–575839bc:18779a938f3:-7f71 … and delete that xml file.
So to fix this you are manually cleaning up a configuration change that did not completely work, deleting the layer, but not deleting its TileSet.
This has also annoyed me for a long time. PR presented in [GEOS-11998] Could not locate a layer or layer group with id ___ within GeoServer configuration, the GWC configuration seems to be out of synch by petersmythe · Pull Request #8947 · geoserver/geoserver · GitHub for consideration
Hi Alex, Jive and Peter,
Issue fixed after permissions fixed on tomcat folders.
Thanks for your response
