Geocentric Datum of Australia 1994, was - Re: [GRASS-user] Convert OGR vector layer to GRASS vector map
On Wed, Jul 15, 2009 at 3:43 AM, benton101<benton.davies@gmail.com> wrote:
2. The command output pane states "Datum <GDA_1994> not recognised by GRASS
and no parameters found". How can I give imported data the correct meta data
for projection? I gather that this will be an EPSG identifier?
I found this:
Maps and the GDA, http://www.icsm.gov.au/gda/mapsgda.pdf
| This map was produced on the Geocentric Datum of Australia 1994 (GDA94).
| Heights are referenced to the Australia Height Datum (AHD).
| For most practical purposes GDA94 coordinates and satellite derived (GPS)
| coordinates based on the World Geodetic Datum 1984 (WGS84) are the same.
| Example 1: Datum information on new map.
Should we add WGS84 as short-cut in the datum table?
Were you creating a new location while importing the file? If not, this message is of no significance - the projection of the location is what will be used.
I found this:
No it's a datum in its own right and should have an entry in datum.table with ellipsoid GRS80 and dx=dy=dz = 0. Before adding it we would need to check what the proper EPSG-based long name should be. I suspect it might be "Geocentric_Datum_of_Australia_1994" but will need to make sure.
Paul
On Thu, Jul 16, 2009 at 12:42 AM, Paul
(GPS)
OK: from http://www.epsg-registry.org/
Code: EPSG::6283
Type: GeodeticDatum
Status: Valid
Domain of Validity: Australia - all states
Remarks / Description: Coincident with WGS84 to within 1 metre.
http://www.epsg-registry.org/export.htm?gml=urn:ogc:def:datum:EPSG::6283
Code: EPSG::6283
Type: GeodeticDatum
Status: Valid
That looks about right then - now added to all versions.
Paul
> Code: EPSG::6283
> Type: GeodeticDatum
> Status: Valid
just to note that AFAIU gda94 is similar to etrs89 in that it is a plate-
locked datum. (and in the last 36 hours I can also report some tangible
observations that these plates are certainly not static!)
Hamish
ps- (OT) http://grass.itc.it/spearfish/php_grass_earthquakes.php
low priority wishes:
  - how to brighten the Blue Marble colormap (RGB raster)? i.landsat.rgb?
  - Richter scale is logarithmic, but bubble radius is linear classed
    to int order of magnitude- the whoppers get hidden in the noise.
