Geonetwork 4.0 to 4.2
Hello everyone, My name is Daniel, I am new to Geonetwork and can you please help me with this: I need to migrate from Geonetwork 4.0 to Geonetwork 4.2. Version 4.0 is currently in Production with 8585 records. Both servers have Postgresql. What is the best option? I’ve read that it can be done with the “Harvest from” option, but I’m not sure which one applies. Thank you.
Hi!
Since you’re staying on the 4.x versions, I would suggest trying the automatic migration first. This means running GeoNetwork 4.2.x against your current database: the migration will happen automatically and there’s a good chance it will work out of the box. You will then only have to re-index your catalog and adjust the various settings.
If you encounter an error in the process you’re welcome to report back!
